Catalytic Converter Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by HoldTheMayo, Apr 24, 2018.
  1. Apr 24, 2018 at 9:42 AM
    HoldTheMayo
    HoldTheMayo [OP] Active Member
    My muffler just went bad so I purchased a new cat back exhaust. I did this before looking under the truck and seeing that the connection is all kinds of rusted together and not going to be salvageable after the new exhaust.
    So, the question. It looks like I have two catalytic converters on the truck.
    Do I need both. The 2nd one or the one closest to the muffler has an 02 sensor in it before the cat and one after the cat. I didn't see on up closer to the motor.
    Did who ever owned this before me just really like Cat's or is this normal on this year?
  2. Apr 24, 2018 at 9:45 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    There are to cats in tacomas, im pretty sure you need both to pass emission checks
  3. Apr 24, 2018 at 9:53 AM
    eon_blue
    Azusa, CA
    Early model 1st gens had one catalytic converter, later models had 2. I can't remember exactly when they switched to 2 cats.
    But yes, if you like in an emissions testing state you will absolutely fail without cats, or without working cats. Also, if you strip the cats the truck will sound awful and pump out tons of smog...I don't mean that in a "save the trees kind of way" but in a "no one will want to be standing anywhere near you and your truck" kind of way.
    Also, OEM Toyota cats are stupid crazy expensive, over $2k for both. Magnaflow makes solid aftermarket options for way less $$$. If you live in CA, your options are limited as CA has strict rules about cats.
    Sperrunner likes this.
  4. Apr 24, 2018 at 10:17 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Are you sure you can't get them apart without ruining the cat? I did my cat back, and although it was a rusty mess under there, I'm still running the OEM cats.
    Also, NY follows the CARB (California Air Resources Board) rules also. If your truck is CARB certified, you have to keep it that way in order to pass NYS annual inspection. Although my truck originated in Maine, it has CARB emissions, which makes the cats more expensive to replace. Check the sticker under the hood.
  5. Apr 24, 2018 at 10:20 AM
    HoldTheMayo
    I'm in FL so no Carb check but don't want to stink things up either.
    This truck was in IL before I owned it and this is the original exhaust. It's time for new pipes.
  6. Apr 24, 2018 at 10:22 AM
    ghs57
    Chops
    Catskill Mts. NY
    What's your mileage? I'm at 170K on my '03 with no problems with the OEM cats.
  7. Apr 24, 2018 at 10:22 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    just run catless if you live somewhere that doesn't care about emissions. no point on spending 4 bills on a cat
  8. Apr 24, 2018 at 10:26 AM
    HoldTheMayo
    About to hit 90,000.
  9. Apr 24, 2018 at 10:37 AM
    ghs57
    Chops
    Catskill Mts. NY
    Wow. She's just a baby. Good luck with the repair.
  10. Apr 24, 2018 at 10:40 AM
    HoldTheMayo
    Yeah, she's in great shape and just trying to keep her that way.
    I have a serious case of OCD which is good until it's not good to my wallet. Looking under my truck created a long list of things I'm looking to replace. :)
  11. Apr 24, 2018 at 10:45 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    What state are you from?? Is it one of the salt belt states
  12. Apr 24, 2018 at 12:10 PM
    Glamisman
    Glamisman Well-Known Member
    there "should" be an emissions sticker under the hood. That will tell you if she was built to Federal Standards (FED), California (CAL), Canadian (CAN) and what it left the factory with... HOS(2) = 2 heated Oxygen Sensors, CAT + CAT = 2 Catalytic convertors or CAT for one.
