Catalytic Converter question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toytaco112, May 15, 2022.
  1. May 16, 2022 at 8:52 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'll certainly take a look, I can't promise I'll be able to tell you anything definitive.
    If you want to upload odd file types on here you will have to put them in a .zip file.
  2. May 16, 2022 at 8:54 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Put the backpressure tester back in the exhaust and have a buddy power brake it while you watch the gauge
    toytaco112[OP] likes this.
  3. May 16, 2022 at 9:02 PM
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    2012 Tacoma DBLCB 4x4 short bed
    King 2.5 Extended travel coilovers, JBA UCA's Deaver stage 2 leaf pack, All pro Aluminum replacement front with 9500lb smittybilt winch, cheap ebay rear replacement, 285.75x16 BFG All- terrains on Method NV wheels, Air ride bags light bars, rock lights bumber light bar And the list goes on..
    i hear densi are the way to go is there a certain one for a certain vehicle model code besides the obvious basic info and eng type or as long as there the four wire?
  4. May 16, 2022 at 9:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I got your thread mixed up with another
    Disregard
    Dm93 likes this.
  5. May 16, 2022 at 9:09 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Denso is the OE manufacturer but part numbers are vehicle and position specific, I wouldn't start replacing parts until it's figured out what's likely bad.
    TnShooter likes this.
  6. May 16, 2022 at 9:19 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just saw the edit in post 1 about a noise and vibration
    If we're sticking with the theory of clogged converters that noise could be an exhaust leak trying to get around the blockage
    Maybe try the back pressure test again? Can you lengthen the hose so you can drive and hold the gauge out the window? Drive around and go up some hills
  7. May 16, 2022 at 9:49 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    For the later 2nd Gen N/A Trucks, the KCLV will default to 14 (unless otherwise configured). Earlier N/A trucks will have it set default to 21.
    A KCLV on a 2nd Gen will not usually ever get up to 27. If you're running 86/87 Octane you'll find they'll typically be 16-12 (positive).
    KFB is default to -3. Anything < than that is "bad" and > is "good".
    Think of KCLV as a long term knock trim that is trimmed by KFB. KCLV doesn't respond to knock directly. IF your KFB goes below -3 (along with other conditions being met), KCLV can and will learn down in 0.22 increments to compensate. There are 3 RPM zones for KCLV on the 2nd Gen and each zone has it's own independent KCLV value giving the ECU the ability to target it's knock correction independent of the other zones.
    Torspd, TnShooter[QUOTED] and Dm93 like this.
  8. May 16, 2022 at 10:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Thank you both for the explanation. I knew there was likely a provision of some type to limit knock.
    And until now, I never knew how it “worked”. I have a “general” idea now. Thanks to both of you.
    Thanks again.
    tonered[QUOTED] and Dm93 like this.
  9. May 17, 2022 at 5:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    TnShooter[QUOTED] likes this.
  10. May 17, 2022 at 9:45 AM
    TnShooter
    Deogee
    STOCK
    For anyone else that is half interested in the KCLV, KFB, and ignition timing. I found this interesting. It’s about the only thing I found in the 1GR.
    I don’t know why, but I’m the type that likes to learn about this stuff. Can’t say I like working on stuff. I missed a good chance to be an engineer. I design it, you build it, and fix it. :rofl:
    https://www.fjcruiserforums.com/threads/toyota-specific-pids.739248/
    winkel and JustDSM like this.
  11. May 17, 2022 at 3:44 PM
    JustDSM
    Justin
    Ogden, UT
    Lots of good info in there, however some of it is not exactly accurate. The patents referenced are for a different Toyota platform and while some of the technical data is correct, it's not 100% accurate for this (and the FJ) platform.
    It takes a little digging but the Tacoma info is out there for those really hungry for it :)
  12. May 17, 2022 at 3:52 PM
    TnShooter
    Deogee
    STOCK
    I see, until OP posted his data. I can honestly say, I hadn’t ever heard of KCLV and KFB.
    While I am interested in the workings, I can’t say I’m too motivated to “really” want to understand it.
    I am the type that goes with, “If it ain’t broke”……
    I haven’t had a broken KCLV or KFB….:rofl:So I don’t have a need to “mess with it”.
    I’ll gladly let you tuner guys figure that one out :thumbsup:
    JustDSM[QUOTED] likes this.
  13. May 17, 2022 at 5:29 PM
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    ILL HAVE TO ORDER AN ADAPTOR LAST TIME I BORROWED ONE BUT YOU MIGHT BE ON TOSOMETHING PLUS I DONT REMEMBER EXACKLY WHAT MY RESULTS WERE LAST TIME EITHER SO DEFINATELY WORTH DOING IT AGAIN... SORRY FOR ALL CAPS DIDNT WANT TO RETYPE IT LOL..
    b_r_o[QUOTED] likes this.
  14. May 17, 2022 at 5:39 PM
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    lokinmg at my log and watching KFB it generally stays at -3 but saw multiple time it changed -4.3, -5.8, -7.2 are a couple numbers it jumped to for a split second then returned to -3
    KCLV stayed at 14.3 the entire time.
  15. May 17, 2022 at 5:46 PM
    #35
    JustDSM
    Justin
    Ogden, UT
    That's pretty typical for running 86/87 Octane on the stock calibration. Toyota was pretty aggressive with the ignition timing in some areas and in my opinion is over advanced. That shows in the KFB values you saw especially the stuff in the <-5 range. That's pretty high knock feedback values.
  16. May 17, 2022 at 6:16 PM
    #36
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    it wont let me upload the HP tuner file. Can send it Email or something if you would like can PM me with however you would like me to send it.
  17. May 17, 2022 at 6:19 PM
    #37
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    My truck has a tune from pretty sure its one of your tunes as well.
  18. May 17, 2022 at 6:28 PM
    #38
    JustDSM
    Justin
    Ogden, UT
    You sure it's one of mine? Who flashed you/when was it? I don’t have any record of your username in my PMs. Or in my client database.
    Send me an email at info@overlandtailor.com with your logs and tune file. I'll gladly take a look. If it's one of ours/mine I can further back off the ignition advance a little if needed.
  19. May 17, 2022 at 6:46 PM
    #39
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You have to put it in a zip file, in Windows right click the file > send to > compressed (zipped) folder and upload that file.
  20. May 17, 2022 at 6:52 PM
    #40
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    yep I just looked at my emails its definatly one of your tunes John is who i talked to But ill shoot you an email right now with the info.
    I flashed it with my tuner and it was back in december. time frame
