Catalytic converter rattling on 2.7l 1996?
Discussion in '1st Gen. Tacomas (1995-2004)' started by z71bowhunter, Jan 14, 2020.
  1. Jan 14, 2020 at 3:01 PM
    z71bowhunter
    z71bowhunter [OP] Well-Known Member
    Randy
    Temple,Ga
    96 Tacoma Ex-Cab 4x4
    Is it possible for it to hurt the fuel mileage by taking this off and busting all the charcoal out of it and putting it back on.I know it turned on my check engine light?
  2. Jan 14, 2020 at 3:22 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    There is no charcoal in a cat.
    I suggest replacing with a Magna Flow replacement.
    Good luck.
    eon_blue and se7enine like this.
  3. Jan 14, 2020 at 3:44 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Yeah if it's rattling most likely the internals have come loose. That happened on the flowmaster cat in less than a year. My magnaflow has lasted twice that and then some.
    Ritchie likes this.
  4. Jan 14, 2020 at 3:46 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    if your catalytic converter is rattling, it means the catalyst element is shot. If you gut your cat converter and put it back this wil trigger a check engine code because of the o2 sensor detecting the emissions as unfiltered. It may or may not cause bad gas mileage, depending if the truck wants to think it's running lean/rich or not.
    There is a way to trick the sensor but it's just better if you put a new catalytic converter back on. Don,t need to be genuine OEM. Aftermarket will do but don't get the most cheapie-cheapo either because they don't last
    Black DOG Lila likes this.
  5. Jan 14, 2020 at 4:03 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Make sure it's not the shield above the cat that's making the noise. Common issue.
    Ritchie and onakat like this.
  6. Jan 14, 2020 at 4:06 PM
    onakat
    Canada
    2000 indestructaco!
    I agree with the above ^^
    forgot to mention it, but yeah, before throwing parts at the truck, check for this first. Would suck to spend $$$ on parts just to find out it was the heat shield :annoyed:
  7. Jan 14, 2020 at 4:14 PM
    Black DOG Lila
    Virginia
    Thanks for the back up. I've had the dreaded P0420 code 3 times in past 5 years, plus the rattling. Haven't had to replace the cats yet. Exhaust leak at flange upstream. A/F sensor B1S1. Exhaust leak at Ypipe donut.
    onakat[QUOTED] likes this.
  8. Jan 14, 2020 at 4:16 PM
    eon_blue
    Azusa, CA
    I recommend Toyota cats if you have pockets lined with gold...nothing beats OEM quality especially when it comes to cats
    For aftermarket, Magnaflow is the next best thing
