2016–2023 Tacoma Catalytic Converter Shield – Bolt-On Theft Protection by Cali Raised LED
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaliRaisedLed, Nov 15, 2022.
  1. Nov 15, 2022 at 12:40 PM
    CaliRaisedLed
    CaliRaisedLed [OP] Well-Known Member Vendor
    Jake
    Texas (DFW)
    Welcome
    Cali Raised LED
    www.CaliRaisedled.com
    Phone: 888-385-5036 l Email: info@caliraisedled.com l Instagram: @cali_raised_led
    https://caliraisedled.com/products/catalytic-converter-shield-for-2016-2023-toyota-tacoma
    Post:
    Catalytic converter theft is a growing concern for Tacoma owners. Our Catalytic Converter Shield offers a robust solution, specifically designed for 2016–2023 Toyota Tacoma V6 models with automatic transmissions. Crafted from 12-gauge 304 brushed stainless steel, this shield provides a durable barrier against theft while maintaining optimal heat dissipation.
    Key Features:
    • Vehicle Fitment: 2016–2023 Toyota Tacoma V6, automatic transmission only
    • Material: 12-gauge 304 brushed stainless steel
    • Design: Laser-cut and CNC bent for precision fit
    • Installation: 100% bolt-on with no drilling or welding required
    • Compatibility: Works with 99% of aftermarket and OEM skid plates
    • Included: Driver and passenger side shields, security hardware, and tool kit
    • Made in the USA: Manufactured in Fort Worth, Texas
    Installation Video:
    For a step-by-step installation guide, watch our video:
    How to Install Catalytic Converter Shield For 2016-2023 Toyota Tacoma | Cali Raised
    Product Link:
    Explore more details and purchase here:
    Catalytic Converter Shield for 2016–2023 Toyota Tacoma
    Feel free to reach out with any questions or for additional information. We're here to help you protect your Tacoma.
  2. Nov 15, 2022 at 12:56 PM
    Trail Limo
    Trail Limo Well-Known Member
    Looks nice!
    CaliRaisedLed[OP] likes this.
  3. Nov 15, 2022 at 1:17 PM
    wrtoyota
    wrtoyota Well-Known Member
    Love the smaller surface area as compared to others. How are they attached? The narrow end looks to be just a plastic plug? Or maybe I'm not seeing the bolts.
  4. Nov 15, 2022 at 1:28 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    https://www.youtube.com/watch?v=PHUJsJztDpM
    If I can find it, you can too!
  5. Nov 15, 2022 at 1:35 PM
    wrtoyota
    Yeah, it looks like the narrow end is not really attached to anything. Maybe I'm mistaken and it is held between something once finally attached, but I would be concern it will flop around.
    TexasWhiteIce likes this.
  6. Nov 15, 2022 at 1:42 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
    It will not flop around. We have product tested it a lot of times on and offroad and have not had any problems with rattle
    D.A.S. Taco and Blak Shinobi like this.
  7. Nov 15, 2022 at 2:28 PM
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    Is an additional security bolt set available to purchase with the shield in case the included set gets stripped of demaged?
  8. Nov 15, 2022 at 2:32 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Yes you can purchase extra hardware!
  9. Nov 15, 2022 at 2:32 PM
    timmy_7x
    timmy_7x Well-Known Member
    EB
    Long Beach, CA
    19 Tacoma SR5
    Can you clarify if this is for 2WD and 4WD or just 4WD?
    Kolter45 likes this.
  10. Nov 15, 2022 at 2:40 PM
    Mbtstaco
    2023 Tacoma Pro MGM
    Are they on the website or do I need to call and order everything over the phone all together? I couldn't find them list.
  11. Nov 15, 2022 at 5:56 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Half the price of the other versions and looks great. Order in!
    D.A.S. Taco and Jerry311SD like this.
  12. Nov 15, 2022 at 6:04 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Thank you for pricing this so people can afford it.
    Ill be placing an order soon.
    TS4x4 and D.A.S. Taco like this.
  13. Nov 15, 2022 at 8:54 PM
    TOR23
    TOR23 Member
    TRD OR 23
    Will this fit 2023? I know it says 16-22. I'm just wondering. If not, are you coming up with one for 2023? Thank you.
  14. Nov 16, 2022 at 3:39 AM
    boi951
    boi951 Well-Known Member
    Boo
    Galveston Island, Republic of Texas
    2020 SR5 2.7 2WD 2009 OR................. 2006 AC.................
    Will it fit a 2020 2.7 4cyl, 2WD?
    Edit: I just crawled under my 4cyl 2WD and looks like it would fit and cover the cat on the passenger side. Since there is no cat on the driver side on 4 cyls I would be game to purchase for 1/2 the price since that's all I need.
    I'd think it would be a good marketing opportunity for Cali since there aren't many affordable cat protection options for us 4 cyl guys.
    iltdi, Spacecoast and D.A.S. Taco like this.
  15. Nov 16, 2022 at 4:34 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    12 gauge and not very wide? Tale an extra 30 secs per cat with a zip disc. Though sadly not much worse than any of the other "cat saver" deterrents I've seen. If I bought this (not that I would) I'd weld those pie cuts shut. Make 'em take an extra minute per side instead of 30 secs.
  16. Nov 16, 2022 at 4:47 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Now that I watched the install video, couldn’t someone just bend the unattached end down and cut the pipe, then go over to the other end on the other side of the cross member and cut the pipe there, then they could just pull the cat out?
    The unattached end seems to be an issue allowing a grab point to bend the guard down easily.
    Kolter45 and mitt22 like this.
  17. Nov 16, 2022 at 5:54 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    Order Placed !!
  18. Nov 16, 2022 at 6:23 AM
    mitt22
    mitt22 Well-Known Member
    Look nice and good price. I agree with others it seems like the front end could use a fastener, but it is hard to judge without seeing a set and how stiff they are.
  19. Nov 16, 2022 at 8:20 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    Could just drill and tap the frame, pretty easy to do..
  20. Nov 16, 2022 at 9:35 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    a significant feature of this style of shield is that it leaves the front propeller universal zerks accessible without having to remove the shield.
    greasing these zerks is required periodic maintenance if you want to maintain warranty.
    and of course stainless steel for 1/2 price of other styles.
    Mark77 and D.A.S. Taco like this.
