2016–2023 Tacoma Catalytic Converter Shield – Bolt-On Theft Protection by Cali Raised LED
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaliRaisedLed, Nov 15, 2022.
  1. Jan 17, 2023 at 5:05 PM
    #461
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Yes they are. They make them in Texas.
  2. Jan 18, 2023 at 7:39 AM
    #462
    TRD_jay
    TRD_jay Well-Known Member
    2022 Off-Road
    Weird.... thought they are the same company and would source from the same place.
  3. Jan 18, 2023 at 8:11 AM
    #463
    MGMTacoGuy
    MGMTacoGuy Active Member
    TRD Pro grill, King's front and rear, Total Chaos UCA, SCS Ray10 wheels, BFG KO2 285/70 17
    I thought so too but I had LED check my order number and they said i'd have to check with OFFROAD because they are too different companies even tho they sell the same product. For some reason, LED is having issues getting the shields from OFFROAD in Texas.
  4. Jan 18, 2023 at 9:17 AM
    #464
    CaliRaisedLed
    CaliRaisedLed [OP] Well-Known Member Vendor
    Jake
    Texas (DFW)
    Cali Raised LED (Us) is located in Fort Worth Texas and we manufacture all of our products here in Texas. Cali Raised Offroad is a separate company that is a dealer of our products located in Southern California. As yall know we are backed up on the production of that product which causes delays.
    SmoPo16 likes this.
  5. Jan 18, 2023 at 12:44 PM
    #465
    CaliRaisedLed
    Jake
    Texas (DFW)
  6. Jan 18, 2023 at 4:39 PM
    #466
    DarkestCon
    DarkestCon Well-Known Member
    DC
    SF Bay Area
    2017 White Tacoma TRD Off Road
    Bone Stock
    Any chance on a version for us MT folk? :spending:
    LuckyScar and MrMustacho like this.
  7. Jan 18, 2023 at 8:27 PM
    #467
    milesbeyond
    milesbeyond Well-Known Member
    Seattle, WA
    ‘23 Solar Octane TRD Pro M/T
    Thanks for this. I will hold out or probably just go with the MillerCAT.
  8. Jan 19, 2023 at 3:08 PM
    #468
    cuser414
    cuser414 Well-Known Member
    2021 tacoma SR5
    I installed the shields on my 2wd v6 today and the passenger side fit perfectly, the drivers side I am not able to get the black rubber piece to line up where it sits touching the truck. The bolts and security screws are all aligned correctly. Has anyone else installed on a 2wd v6? If so are you seeing the same?
  9. Jan 19, 2023 at 5:58 PM
    #469
    tacos4u
    tacos4u Active Member
    I don’t think it matters as long as all the bolts are tight!!
  10. Jan 19, 2023 at 6:19 PM
    #470
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I had to put some spacers on my security bolts to get it off the cat. My rubber bumper just hangs out in space now… no contact at all.
    BOMBS likes this.
  11. Jan 19, 2023 at 6:27 PM
    #471
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Did I miss something? Why are you concerned about a metal shield getting hot from the cat?
    TS4x4 likes this.
  12. Jan 19, 2023 at 7:25 PM
    #472
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Mine was pressed up against my cat too, so I added a couple washers to make some space also. But I was more concerned with the cat and shield rubbing against each other, and what kind of wear and noise might come from that, especially over the next 20 years or so (I plan to keep my truck for the long haul). Cats already get so hot too, I figured they probably don’t need anything pressed up against them, possibly making them even hotter.
  13. Jan 20, 2023 at 4:57 AM
    #473
    RushT
    North Texas
    It rattled pretty bad. Annoyance factor was too high.
    WaitingOnMyR1T[QUOTED] and BOMBS like this.
  14. Jan 20, 2023 at 5:56 AM
    #474
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    How many washer did you use and what size?
  15. Jan 20, 2023 at 6:09 AM
    #475
    RushT
    North Texas
    I’ll check thickness when I get back home today. I picked up some nylon washers from Ace a while ago. Probably 1/4” +- a little.
    Barsoom and BOMBS like this.
  16. Jan 20, 2023 at 6:58 PM
    #476
    RushT
    North Texas
    Single washer on each security bolt on the driver’s side. 3/4” OD and a wee bit over 3/16” thick. ID enough for the bolt, around 5/16” if I remember correctly from the garage to my warm butt spot on the couch.
    BOMBS[QUOTED] likes this.
  17. Jan 21, 2023 at 10:52 AM
    #477
    junkyarddogg
    junkyarddogg Well-Known Member
    New Jersey
    2021 TRD Off Road
    Installed today. This section is touching the cat on the driver side. Will this cause any issues?
  18. Jan 21, 2023 at 11:55 AM
    #478
    RushT
    North Texas
    I don’t know, but mine rattled and I couldn’t deal with that. Mostly when cold or backing up.
    fasteddie23 likes this.
  19. Jan 21, 2023 at 12:49 PM
    #479
    Grimble27
    Grimble27 Well-Known Member
    Washington
    '23 White Tacoma TRD OR
    Even with a washer between the shield and the cat?
  20. Jan 21, 2023 at 12:52 PM
    #480
    RushT
    North Texas
    It’s all good now.
    Grimble27[QUOTED] likes this.
