2016–2023 Tacoma Catalytic Converter Shield – Bolt-On Theft Protection by Cali Raised LED
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaliRaisedLed, Nov 15, 2022.
  1. Feb 19, 2023 at 12:24 PM
    #601
    broderwd
    broderwd New Member
    Cincinnati
    2021 Toyota Tacoma TRDOR
    If you have access to a dremel you could cut it into a flathead. Additionally, unbolt the 3 other bolts to the protective bar and then you can rotate the bar which should help get it started coming undone.
    Don't ask how I know this works....
  2. Feb 19, 2023 at 1:41 PM
    #602
    christsay
    christsay Well-Known Member
    chris
    Austin, TX / Santa Fe, NM
    2021 Army Green DCLB TRD 4x4
    JB Grand Raid Evo XXL mounted on an Alu-Cab. 5.29 gears.
    I think you installed the rear portion wrong, the shield is supposed to go over the cross bar not attached to the front.
    2WD vs 4WD difference.
  3. Feb 19, 2023 at 1:48 PM
    #603
    christsay
    chris
    I played around with some spacers on the forward crossbar mount where the security bolts would go and I found that I had more rattles the more spacers that were added with the least amount of vibration (i.e. basically none) with no spacers installed. There is definitely some truck to truck variation here, I expect that exhaust movement will be a function of the condition of the engine mounts etc and our truck is fairly new but I could see how a tight fit = no noise.
    TRDRed[QUOTED] likes this.
  4. Feb 19, 2023 at 1:48 PM
    #604
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Nope, it's different depending on which version.
    The okd 4WD design goes over the crossbar and bolts on the rear.
    The 2WD version has open slots for sliding under the bolt heads in front of the crossbar.
    It will be obvious which version you have, because there's no way it will fit if you place it on the wrong side of the bar.
    TRDRed and christsay[QUOTED] like this.
  5. Feb 19, 2023 at 2:04 PM
    #605
    junkyarddogg
    junkyarddogg Well-Known Member
    New Jersey
    2021 TRD Off Road
    Very odd, mine is super tight without any washers and it rattles, specifically on acceleration. Almost sounds like an obnoxious ricer exhaust is nearby.
    BigO79 and TRDRed like this.
  6. Feb 19, 2023 at 2:19 PM
    #606
    christsay
    chris
    Ah thanks, I had no idea!
    Rock Lobster[QUOTED] likes this.
  7. Feb 20, 2023 at 9:23 AM
    #607
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    Also good info and makes sense. :thumbsup: Planning on installing them per the instructions initially. Hopefully that's all it takes.
  8. Feb 20, 2023 at 9:25 AM
    #608
    TRDRed
    CenCal805 and 50Buck like this.
  9. Feb 20, 2023 at 3:08 PM
    #609
    Barrister
    Barrister Well-Known Member
    Dennis
    Mesa, Arizona
    2023 TRD Pro, Solar Octane, 6 speed Manual
    Predator Steps, OEM Tonneau
    Are there plans to make one for the 4X4 V6 Manual transmission models?
  10. Feb 20, 2023 at 3:46 PM
    #610
    CenCal805
    CenCal805 Well-Known Member
    California
    2016 Tacoma TRD OR AC
    Mine said 3-4 weeks lead time when I ordered on Jan 21st, still no communication from them. I'm not in a hurry since I knew others were waiting 6-8 weeks before I ordered.
  11. Feb 20, 2023 at 3:57 PM
    #611
    TRDRed
    Patience is a virtue. :thumbsup: I have none, but admire those who do! ;)
    Curious which company did you order it from? Caliraisedoffroad or Caliraisedled? Two different companies. More here:
    https://www.tacomaworld.com/threads...2016-2022-tacoma.784146/page-24#post-28288605
    I ordered from the OP, Caliraisedled about 3 weeks ago. Received a confirmation email and receipt right away. Nothing since though.
    CenCal805[QUOTED] likes this.
  12. Feb 21, 2023 at 9:36 AM
    #612
    CenCal805
    California
    I ordered from CaliraisedLed. I received the same right after I ordered but nothing since.
  13. Feb 21, 2023 at 11:23 AM
    #613
    Eddie1958
    Eddie1958 Well-Known Member
    ED
    I guess I got a little wait I ordered on Feb 9. I also did not get anything after they took the cash. It says 3 to 4 weeks lead time that may be optomistic.
    TRDRed and CenCal805 like this.
  14. Feb 21, 2023 at 11:45 AM
    #614
    CenCal805
    California
    You didn't get a confirmation email like this?
    That is the only email I've received since placing the order on Jan 21st.
    TRDRed likes this.
  15. Feb 21, 2023 at 12:18 PM
    #615
    MTBTACORN
    MTBTACORN Well-Known Member
    Ontario, Canada
    23 Tacoma TRD Pro 21 Sportster S
    This may be a good sign that the cat shield production is picking up. Posted yesterday on the Gram.
  16. Feb 21, 2023 at 12:22 PM
    #616
    CenCal805
    California
    Why would they be shipping out "yet to be purchased" shields to Hawaii before filling orders?
  17. Feb 21, 2023 at 12:26 PM
    #617
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Just a weird guess, but that was probably a filled order. Fabricators sell to resellers too...
    TRDRed, SmoPo16, MTBTACORN and 2 others like this.
  18. Feb 21, 2023 at 12:29 PM
    #618
    CenCal805
    California
    Hey Ryan... Yeah, could be. I guess I just assumed that the message to hit up MJM Motorsports if you wanted one meant that they were shipping those to them and would be in stock.
  19. Feb 21, 2023 at 3:06 PM
    #619
    TRDRed
    Reseller...
    https://mjmotorsports808.com/produc...wd-version?_pos=2&_psq=catalytic&_ss=e&_v=1.0
    https://mjmotorsports808.com/produc...023-tacoma?_pos=3&_psq=catalytic&_ss=e&_v=1.0
    Both 2WD and 4WD show out of stock on their website.
    No idea if they warehouse them or just use Caliraisedled as a drop-shipper though. Nice to see boxes are ready to be shipped out... hope more are coming our way soon.
  20. Feb 21, 2023 at 3:13 PM
    #620
    MTBTACORN
    Ontario, Canada
    Looks like CaliraisedLed is shipping a fulfillment order to MJmotorsports so they can sell them in their store. They’re still showing out of stock since Cali was just getting them ready to ship out yesterday. Guessing it’ll take a few weeks to arrive in Hawaii from Texas.
    Just nice to see a big batch of them ready to ship. Things are moving.
    CenCal805 and TRDRed[QUOTED] like this.
