Catalytic Converter Special Service Campaign (2010-2014 4 cyl Tacomas)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Pete626, Nov 6, 2015.
  1. Jan 6, 2016 at 2:00 PM
    #141
    Clearwater Bill
    Billy
    Largo Florida
    Had my replacement done today. No drama. I called around the holidays, they ordered the parts. Called and told me they were in. I made the appt to drop it off, picked it up 4 hrs later.
    For giggles I googled the PNs on the invoice, and all are available via Amazon for about $1200 total.
    I did crawl under when I got home and looked it over. Everything is in order it appears, no hanging wires or other stuff knocked loose, everything all lined up nice and neat.
    I only have <15k on my '13, so no running issues noted. But I'm sure it must be faster now. Where's my stickers??
  2. Jan 6, 2016 at 2:06 PM
    #142
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I had no loss of performance when my first catalytic converter failed.. so I wouldn't say it's a guaranteed symptom. MPG was the same, power was the same.. it just rattled like crazy.
  3. Jan 13, 2016 at 8:23 AM
    #143
    brow
    brow Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    Got my cat replaced yesterday, and definitely noticed a power and acceleration difference, not to mention it got rid of one of my rattles that I thought was coming from under the hood, and another that would happen every time the engine went through 1500-1600 RPM's. I must have had a partial failure inside the cat and things were starting to knock around and partially restrict airflow. 1800.00 worth of repairs for free at 102,000 miles, I can't complain about that.
    Also got to play the fun game of how many toyota service techs try to move my truck before they find the one that can drive a stick. Fun fact, its usually the only female working in the shop.
    Toyko Joe likes this.
  4. Jan 13, 2016 at 8:31 AM
    #144
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    LOL That must of been quite funny (although if you were in a hurry to get it repaired it may not have been ..)
    Also Just FYI I'll have mine done in the spring - but I had the TSB for "cold soak shudder" (E prom update) and It looks like I gained a couple MPG and it does run, Idle better - with little bog on long up hills.
  5. Jan 13, 2016 at 8:18 PM
    #145
    Taco Pete626
    Taco Pete626 [OP] Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    The first time I picked up my truck from the complimentary service, I saw the porter shift my truck from first to second but when he realized how tall 2nd gear was, he didn't seem to know what to do, so he tried shifting it to first (I am assuming). It was a bit entertaining watching him struggle at first, but then I started getting really worried, but luckily he couldn't get it in while the truck was moving and had to stop in order to put it back in first. He then drove up to me revving the piss out 1st gear. Good times...
  6. Jan 20, 2016 at 5:16 PM
    #146
    Taco Pete626
    Peter
    Southern California
    You must have lenient smog inspections.
  7. Jan 20, 2016 at 6:48 PM
    #147
    Hill William
    Hill William New Member
    2012 Tacoma Reg Cab 4x4 with 2.7L
    None
    Had mine done on New Year's Eve. Prior to doing the work they said they needed to inspect it and then order the parts. The service manager said we need to "make sure nothing is getting hot." Huh? This is a Special Service Campaign not a Safety Recall. I stopped parking in the garage after that slip.
    Replacement was simple, about 2 hours, $2300 later at no charge.
    Here's the rub, my fuel economy was always 21.5 to 21.8, could bank on it. Now it's 19.5 for 2 tank fulls. Another thing that bothers me is now it won't shift to overdrive until the engine heats up. I suspect Toyota dumped a new program in the PCM to season the converter. I am not satisfied at all with this turn of events.
  8. Jan 20, 2016 at 9:21 PM
    #148
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It isn't supposed to. You are probably noticing it more since the weather is colder.
    T4RFTMFW likes this.
  9. Jan 21, 2016 at 3:33 AM
    #149
    Hill William
    None
    While coasting down slight declines at 40 mph the truck is engine braking when cold, cold is a relative term in this instance, I live in the South. The power train is unloaded. There is no reason not to shift. I have owned the truck for four years, it has never hung in third for this long. It has a whopping 38k miles on it. I am an ex-transmission engineer.
  10. Jan 21, 2016 at 5:25 AM
    #150
    Canufixit
    New England
    Did you check our the TSB list for "Cold soak" Engine vib/shaking and transmission shifting when cold ? It's for the i4. IT helped my mileage, shuddr and shifting on my 2012.
  11. Jan 21, 2016 at 12:59 PM
    #151
    Jimmyh
    SC
    2012 Prerunner SR5
    If you are unhappy with the results take it back and ask questions. I also live in the South and when it is cold it doesn't shift into OD until it is warmed a bit. Never has.
  12. Jan 21, 2016 at 6:06 PM
    #152
    Hill William
    None
    No duh Jimmy. Take it back. Wow.
    Well sir, for the first four years it did and now it doesn't. Cause and effect.
  13. Jan 21, 2016 at 8:38 PM
    #153
    Jimmyh
    SC
    2012 Prerunner SR5
    You don't have to get all pissy about it.
    You suspect that they loaded a new program into the truck that you don't like.
    I made a suggestion to take it back and ask questions.
    Obviously you don't like that either.
    Cause and effect doesn't always hold true.
    I guess since you are an " ex-transmission engineer " you could just figure it out yourself and fix it or just enjoy your non shifting transmission.
    There is a lot of good help here in these forums, but if you act like an @ss about it the help is usually not as plentiful.
    Maybe you could try sending a PM to gearcruncher. He is the transmission go to guy here.
  14. Jan 22, 2016 at 4:49 AM
    #154
    Canufixit
    New England
  15. Jan 22, 2016 at 10:55 AM
    #155
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    dealer finally called me today. Parts are in after 7-8 weeks. Going Monday to drop off the truck.
  16. Jan 22, 2016 at 6:43 PM
    #156
    Taco Pete626
    Peter
    Southern California
    During the first couple of days I noticed something different about my truck too. Wasn't quite sure what it was, but something changed. It might be more noticeable to me since I put at least 25,000 miles a year on my truck. Could it be the ECU relearning? Who knows. Anyways, after the first week, I unplugged the battery, gave it about 30 minutes and plugged in back in in hopes of resetting the ECU. I travel about 80-90% highway, maintaining 70mph and I get 27-28, about the same as I always have. I live in Southern California so my cold morning starts happen in the mid to high 40s (some of you might not even consider that to be "cold") so it might not affect me as much.
  17. Jan 22, 2016 at 7:28 PM
    #157
    Jimmyh
    SC
    2012 Prerunner SR5
    Non-issue. It isn't supposed to shift until it warms a bit. Mine never shifts into OD until it gets up to about 130 degrees engine temp as read by Ultragauge.
  18. Feb 11, 2016 at 4:10 AM
    #158
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Had the service done. Truck is quieter, no other noticeable changes.
  19. Apr 6, 2016 at 3:24 PM
    #159
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Got mine done a couple weeks ago, got the letter in November :oops: Went to Clint Bowyer Toyota in Emporia KS. My appointment was at 11am, left the truck and went to an early lunch with a friend. 11:45 my phone rings, truck is done. Easy in, easy out.
    According to my UG I'm getting almost 2 mpg better, but too soon to tell for sure.
    Anyone else had to try to answer their phone while holding a greasy, AWESOME bacon cheeseburger? :)
    EDIT: The service manager said several times ... recall. Should I have chastised him as some do on these forums? lol
  20. Apr 6, 2016 at 7:22 PM
    #160
    Taco Pete626
    Peter
    Southern California
    Absolutely!
