Catalytic converter stolen !
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kdubcr250, Mar 25, 2014.
  1. Mar 25, 2014 at 5:29 AM
    Kdubcr250
    Kdubcr250 [OP] Member
    I live in a fairly rural area went out to start my truck this morning and saw someone roll out from under my truck. I yelled at the person and ran after him but let's just say I wasn't warring the right attire for a high speed foot pursuit. Anyway a new cat is just out of my budget at this time. Question is if someone in this position was to put a straight pipe in it's place would it damage anything ? What about not having 02 sensors ?
  2. Mar 25, 2014 at 9:11 AM
    Kdubcr250
    Wow 75 views and no advise lol.
  3. Mar 25, 2014 at 9:12 AM
    JRod4928
    JRod4928 Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    Someone just had this happen to them a few days/weeks ago. Use the search function.
    I think I remember them saying that your insurance might cover part/all of it (might).
  4. Mar 25, 2014 at 9:29 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Just read about this on other thread. Maybe tech chat?
  5. Mar 25, 2014 at 9:36 AM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    Have you tried seeing if insurance would cover it
  6. Mar 25, 2014 at 9:39 AM
    TJGARZA84
    TJGARZA84 Well-Known Member
    TIM
    SAN ANTONIO
    2012 TOYOTA TACOMA PRERUNNER SR5 - BLACK
    TINT - 20% FRONT - 5% REAR 3 INCH LIFT PAINT TO MATCH GRILL AND REAR BUMPER REMOVED ALL EMBLEMS
    Some one rolled out from under your truck - I carry and would still freak a bit considering a have a mild lift and can usually see a good portion under my truck.
    should have run over his ass ....
    anyway - best of luck - call insurance.
  7. Mar 25, 2014 at 9:40 AM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    i would flip shit if i saw the little bastard roll out from under my truck and run away with the cat.
    wow
    so sorry. hopefully insurance will cover it.
    have heard about some people doing straight pipes
  8. Mar 25, 2014 at 10:28 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    depends on where you live as far as emissions.
    The point of a CAT is to burn unburn fuel vapors and the O2 sensor determines how well the CAT is doing it's job. The O2 sensor also communicates with the ECM to "tune" the fuel levels based on current RPM, Air across the MAF, injector duty cycles, etc.
    So no, save the straight pipe for the V8 & carb & SAS conversion.
  9. Mar 25, 2014 at 11:09 AM
    Kdubcr250
    Ok thanks.
  10. Mar 25, 2014 at 11:15 AM
    Goodmark
    Goodmark Member
    Mark
    Central NJ
    '13 Dbl Cab Short Box
    What Tim said.:cool:
  11. Mar 25, 2014 at 11:22 AM
    Drcoffee
    Drcoffee Member
    99 4Runner SR5
    You would need an O2 simulator but yes you could put a straight pipe in so long as your state does not do visual inspections.
    *I am a non-attorney spokesman
    Of course you will only use this truck off-road. LOL
  12. Mar 25, 2014 at 1:47 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    I had mine stolen a while back and I welded a temporary pipe on till we could put a new cat in.
  13. Mar 25, 2014 at 3:22 PM
    Andy.G
    Andy
    Virginia
    We all either want to,or we raise our trucks and make a cat target for these shits!!
  14. Mar 25, 2014 at 6:56 PM
    Kdubcr250
    The p.o.s cut it off before the front o2 sensor so that's more $ down the drain. Although it did find the 78 cents that fell out of his pocket while he was cutting.
  15. Mar 25, 2014 at 7:00 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Call insurance and since you're rural, maybe a nearby convenience store or gas station caught this guy on camera around the time he high tailed it?
  16. Mar 25, 2014 at 7:01 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Ya like last week someone had this happen too. What's the deal? Sorry to hear.
  17. Mar 25, 2014 at 7:06 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    I would put in an aftermarket cat and buy a URD o2 simulator to make the computer think its up to par. This will keep your truck running like stock.
  18. Mar 25, 2014 at 7:09 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    With no 02 sensors and a straight pipe your truck will run like shit. Bad mpgs lacking of power. You comp will put you in limp mode. It may not fuck anything up permantly but its better to fix it sooner than later.
  19. Mar 30, 2014 at 5:31 PM
    Kdubcr250
    Update. Drove truck to a local muffler shop had a pipe put where the cat. was and a o2 sensor replaced. 300 miles and no issues so far except p0420 code from not having a cat. ( had that before it was stolen). Mph seems to not have changed and truck is still super quite. Seems to run better as well. Oh and it just rolled over to 100k not bad for a 97 lol.
  20. Mar 30, 2014 at 6:17 PM
    Andy.G
    Andy
    Virginia
    That's great man. Maybe your cat was a little clogged before. I will do same thing when mine goes. Thanks for ending.
