catalytic converter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brecop, Feb 15, 2017.
  1. Feb 15, 2017 at 9:07 PM
    Brecop
    Brecop [OP] Member
    Has anyone have experience with removing the second cats?The sensors O2 are for and aft of the primary ones. Will the loss of backpressure cause issue? Any information will be helpful since previous owner replace exhaust with 2" after cats
  2. Feb 15, 2017 at 9:35 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    URD sells a Y-pipe with the 2nd cats removed. Doesn't cause an issue.
  3. Feb 15, 2017 at 9:43 PM
    Brecop
    Brecop [OP] Member
    What about daily performance/driveability with removed? What is the purpose of them??
  4. Feb 15, 2017 at 9:48 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Secondary emissions cleanup. It is technically illegal to remove any emissions control device, so factor if your state does inspections and how thorough. With them removed it will reduce back pressure, which in theory leads to higher performance.
  5. Feb 15, 2017 at 9:56 PM
    Brecop
    Brecop [OP] Member
    Thank You. I guess technically they can get plugged. 103k on a 08 4.0. I'm not charged yet, but debating. Stock, it doesn't come on until 2500rpm.
  6. Feb 16, 2017 at 7:20 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Backpressure is never good, and that reducing it can cause loss of power is a Fast & Furious, "magazine mechanic" myth.
    Read more here
    , and here...
  7. Feb 16, 2017 at 9:48 AM
    Whitetrash
    Whitetrash Well-Known Member
    Jimmy
    San Diego CA and Enon OH
    2008 Prerunner Regular Cab SR5
    Wheeler's AAL, 5100s at 1.75, 265/75r16
    agreed!
  8. Feb 16, 2017 at 9:54 AM
    EricU
    EricU Well-Known Member
    Englewood, CO
    had the rear 2 removed on my last 2nd gen, 2.5" y pipe, 3" outlet after the muffler, no loss/gain in power (All SS Mandrel bent). slightly different exhaust tone,
    IF you have the skill to build an exhaust system, ya might go ahead and removed them just to start the exhaust at a new flange to clean things up. but i could not justify the fancy y-pipes from any company unless you were running boost. Exhaust re route for clearance and slap on whatever cat back/muffler you like and call it a day.
