Catalytic converters, and O2 sensor recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Osito, Dec 12, 2020.
  1. Dec 12, 2020 at 10:25 PM
    Osito
    Osito [OP] Member
    Alejandro
    Tacoma 2006 Trd
    I need to replace them for my 06 Tacoma. What websites, and brands do you guys recommend? Budget friendly.
  2. Dec 12, 2020 at 10:50 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Dec 15, 2020 at 1:30 PM
    Oklatacoma
    Oklatacoma Member
    Oklahoma
    2005 Tacoma V6
    The link goes to a page of 7 options and I can't figure out if all are options with different performance ratings or if only a few are compatible with my vehicle. 2005 Tacoma V6. Can you elaborate on this response for me, I'm a dum and I've been dealing with a P0420 error code for several months now. The cats were the first suspect on the list of causes but also the most expensive, so I went down every other rabbit hole trying to avoid the cost of replacing them. 2020 has not been kind to my bank account so spending $1,500 to replace both cats isn't very appealing.
