Catalytic Converters
Discussion in 'Technical Chat' started by IndianTaco, Apr 16, 2012.
  1. Apr 16, 2012 at 6:05 AM
    IndianTaco
    IndianTaco [OP] Well-Known Member
    got some codes this weekend saying my converters are not up to par. should i replace the converters with DTLTs and a URD y-pipe, or just replace the converters? :confused:
  2. Apr 16, 2012 at 6:17 AM
    Devux
    Devux Well-Known Member
    Devin
    Las Vegas, NV
    2014 TRD Sport 4x4
    Leveling kit & wheels
    Check your warranty, if I remember correctly the emission control system has a long warranty like six or seven years. If so get it back to Toyota.
  3. May 26, 2012 at 12:24 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Try cleaning the cats before you spend hundreds for new ones.
  4. May 26, 2012 at 6:10 PM
    toy.tech21
    toy.tech21 Active Member
    Evan
    Lakewood CO
    2008 Doublecab 6 speed
    K&N intake, URD short throw shifter, toytec boss front coilovers, old man emu dakars, led's in gauge cluster, dome and map light led's
    Theres no way to clean out the cats. If the turck is throwing cat codes then the only thing to do is replace them. Toyota does have a longer warranty on cats so it wouldnt be a bad idea to look into that. But if your going to replace them then I suggest only toyota factory parts and not aftermarket ones because they never last.
  5. May 26, 2012 at 6:23 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    I personally use this
  6. May 26, 2012 at 6:48 PM
    koco
    Bay Area Ca.
    '01 Taco
    Thats a clean cat. lol
    Detergent, enzymes or citric acid can be used to clean a cat. The material inside gets coated with greasy soot and it reduces it's efficiency. As long as the material is not melted, it can be cleaned out.
  7. May 26, 2012 at 6:56 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    pics or it didnt happen:)
  8. May 26, 2012 at 6:58 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    8yr/ 80,000 miles IIRC
  9. May 26, 2012 at 7:29 PM
    koco
    Bay Area Ca.
    '01 Taco
    This cat is clogged. Remove the offending particles, and it will work again.
  10. May 26, 2012 at 7:31 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Federal law mandates a 70,000 mile warranty on emissions components in the US.
  11. May 26, 2012 at 7:39 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    i understand the concept, i just wanna see someones actual before and after pics
  12. May 26, 2012 at 7:39 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    i thought it was 80,000 or 8 years
  13. May 26, 2012 at 7:42 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It might be... it's been a LOOOONG time.
    I had an emissions issue on my '91 Ford Escort at about 65k back in '94 and the dealer fixed it saying they had to fix it up to 70k.
  14. May 26, 2012 at 7:44 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    yeah, im at 150,751. so its not helping me:mad:
  15. May 26, 2012 at 7:46 PM
    Johns Taco
    Albuquerque, NM
  16. May 26, 2012 at 7:54 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    talk about nutz. can u imagine removing both of your manifold cats and cleaning them over night? fucuk, sound like a big disappointment waitin to happen:(
  17. May 27, 2012 at 6:56 AM
    IndianTaco
    LOL
  18. May 27, 2012 at 10:10 AM
    toy.tech21
    Evan
    Lakewood CO
    Cats are very sensitive. An engine running too rich or misfiring too bad can cause then cats to quit working or even melt so cleaning them our with a detergent or paint any other substance is a really bad idea and will only make things worse. And the dude in that video has got to be hitting the pipe. I would absolutely never pour paint thinner in my gas tank ever! talk about damage to injectors or other fuel components.
  19. May 27, 2012 at 12:09 PM
    koco
    Bay Area Ca.
    '01 Taco
    Yeah the laquer thinner through the tank is likely harmful to injector seals and other rubber parts. It would probably burn off before reaching the catalytic.
    Catalytics have platinum inside which is a hard metal, and besides why would you care if it got destroyed if you were gonna replace it anyhow? The platinum is harder than the sludge, sulfur and unburned fuel additives that become stuck to it.
    Cleaning it is worth a try. For some reason people are against the idea. :washing: So go out there and put yer cat in the washer!
  20. May 27, 2012 at 12:18 PM
    Johns Taco
    Albuquerque, NM
    x2
