Catalytic converters?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dlead, Feb 6, 2017.
  1. Feb 6, 2017 at 1:53 PM
    Dlead
    Dlead [OP] Well-Known Member
    Daniel
    North carolina
    1998 toyota tacoma ext cab
    Bilstein 5100s with old man emu coils and 2 inch body and 33s and cold air intake and throttle body spacer.
    What is everyone using for aftermarket catalytic converters?
  2. Feb 6, 2017 at 1:58 PM
    BDMcGuire
    BDMcGuire Well-Known Member
    Brent
    Peoria, AZ
    06 Tacoma OR SBDC
    Do you have emission testing in NC? If not just straight pipe it! Or if you do get a bypass sensor and again, straight pipe it!
  3. Feb 6, 2017 at 2:25 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
  4. Feb 6, 2017 at 2:34 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Yea, magnaflow on my Civic Sir and another in the garage for the Tacoma this spring.
  5. Feb 6, 2017 at 3:15 PM
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    Not going for a thread jack here, but came to post up almost the same exact question and saw this question. Basically same question, but looking for CARB compliance...
    Has anyone tried the magnaflow CARB / CA Compliant converters? It's looking like I also need to replace mine, but am selling in the not too distant future, and really can't see spending OEM converter type money on a truck that likely won't fetch me more than $5k at this point.
    And before I spring for two converters, is one or the other (front or rear converter) more likely to go out first or have a better chance of passing smog and clearing the dreaded P0420 code for good?
  6. Feb 6, 2017 at 3:33 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    I just bought a Magnaflow for one of my trucks. I haven't had a chance to install yet but keep in mind if you go this route AdvanceAuto Parts sells them and if you use code TRT41 you get $40 off every order of $100 dollars or more. Hands down best price I was able to find on Cats at this point.
  7. Feb 6, 2017 at 6:54 PM
    scheide
    scheide Well-Known Member
    nebraska
    84 toyota
    4.88 gears, marlin crawler, 4" lift,lockers front and rear,33x10.5 swampers, header, u-bolt flip kit,relocated shocks in rear,walker muffler, pinion e-brake conversion,9000 ramsey winch.
    Hey BDM, please explain what I would need to do to run a straight. What is all involved in installing a bypass sensor? I don't want any lights flashing or anything on my dash.
