Catalytic Coverter Identification
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Andy Gravity, Mar 18, 2009.
  1. Mar 18, 2009 at 11:18 AM
    Andy Gravity
    Andy Gravity [OP] New Member
    So Cal
    2005 TRD
    I am planning on installing a Catalytic converter theft deterrent on my 2005 Tacoma. I can't seem to figure out where it is. There seem to be four pipe "swellings" coming on the exhaust system. One of which has a metal shield around it. Is that the catalytic converter??
    Thanks in advance for any help.
  2. Mar 18, 2009 at 11:20 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    yes it is... theres 4 of them, two are tucked up in the engine bay, and the other two are on the y-pipe, one has the shield on it
  3. Mar 18, 2009 at 11:44 AM
    Andy Gravity
    So Cal
    2005 TRD
    Thank you!
  4. Mar 18, 2009 at 2:29 PM
    bigrog74
    bigrog74 Well-Known Member
    Florence, SC
    08 Tacoma Off Road Rugged Trail
    Coming Soon....real soon
    Funny you say that. My wife said that someone cut off 2 catalytic converters from Toyota vehicles at her place of business in the past 3 weeks.
  5. Mar 18, 2009 at 2:40 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Should of hung out for the bad guys....they know where your cats are. I'm sure they would of showed you. Ok, now that you have our interest....what pray tell is the device to end this "cat" thievery? Armour plate the entire undercarriage? If you just cover just the cats....they will just keep cutting down the length of the pipes till they get to where they can still do the damage.
    Please go on with your mod but share it with us.
  6. Mar 18, 2009 at 2:45 PM
    Andy Gravity
    So Cal
    2005 TRD
    I guess I should have looked under there first. I bought a Catcuff, but now I am worried that I won't be able to lock them up since there are 4 of them.
  7. Mar 18, 2009 at 2:47 PM
    tacoskim
    Los Angeles, CA
    Stock
    the first two are gonna be hard for them to get. the 2nd pair are easy. i just replaced the y-pipe with the pipe bomb so when those crackers go under my truck they see that i have no cats so hopefully they'll move onto the next taco
  8. Mar 18, 2009 at 2:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It should be easy to protect the cats. You can install some sheet steel and connect it to the cross member after the cats, and to the frame to the side of the cats. With some good bending, it will fit good, and allow no access to the cats.
