Catastrophic failure caused by lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Dec 24, 2012.
  1. Dec 24, 2012 at 12:02 PM
    prerunnerSD
    prerunnerSD [OP] Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Catastrophic failure caused by lift or suspension I've had this lift in my truck for over a year and everything seems fine I have adjustable Billstein coils in the front and adjustable Billsteinsd in the back as well as slightly larger tires installed by a pro. As you see in the photo the driver side's Tire rod or CV joint I'm not sure snapped luckily I was only going 20 miles an hour and no one else on the road and I came to a stop safely and I'm okay except for a bump to the head but it could've been much worse.
    Truck is in the shop looking for answers of how I can prevent this from happening in the future. Is there anything I should tell the shop to reinforce or look out for?
  2. Dec 24, 2012 at 12:03 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  3. Dec 24, 2012 at 12:04 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Looks like the lower balljoint failed, which then caused the cv axle to pull out of the housing.
  4. Dec 24, 2012 at 12:06 PM
    98tacoma27
    Ben
    Not Beech Creek
    x2...and the lift is not the cause. It can and does happen to stock vehicles
  5. Dec 24, 2012 at 12:07 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Sucks man I'm glad your ok. I'm with the other two and not thinking the lift caused this. My 2000 runner has been lifted a lot longer than that with out this issue.
  6. Dec 24, 2012 at 12:13 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
  7. Dec 24, 2012 at 12:14 PM
    prerunnerSD
    USA
    what should i do to prevent this happening??? can i beef it up somehow
  8. Dec 24, 2012 at 12:17 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Yep. Lower ball joint failure. Probably not related to lift or tires...
    Nothing you could have done. LBJ just failed and they are not grease-able so its not a maintenance issue.
  9. Dec 24, 2012 at 12:18 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    get MOOG ball joints, cant really do anything to stop it besides switching to a uniball. which you need custom lowers and a custom spindle made, mise well just go LT if you do that......
  10. Dec 24, 2012 at 12:19 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You just need to keep an eye on the LBJ bolts. My buddies almost blew out too on a trail. Only have two bolts half way in.
  11. Dec 24, 2012 at 12:21 PM
    97yota4wd
    Eric
    Mesa, AZ
    the actual balljoint failed, not the other thingy thas has 4 bolts in it. sorry dont know what its called.
  12. Dec 24, 2012 at 12:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lower spindle mount :notsure:
    and true..really could just go LT haha
  13. Dec 24, 2012 at 12:33 PM
    prerunnerSD
    USA
    the other side is leaking grease too...
  14. Dec 24, 2012 at 12:40 PM
    prerunnerSD
    USA
    so was it the ball joint or spindle mount that failed? with the wayu they towed it.. they didnt seem to know what they were doing.. they may have caused even more damage to under carraige
  15. Dec 24, 2012 at 12:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    BJ i think..
  16. Dec 24, 2012 at 12:42 PM
    2000GTacoma
    Snow Hill NC
    the balljoint and spindle mount are supposed to be one piece. That is considered the lower balljoint. 4 bolts bolt it to the spindle with a taper bolt with a castle nut that bolts to the lower control arm.
  17. Dec 24, 2012 at 1:16 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Toyota makes great vehicles. Their ball joints are the least great components in them. Why is that?
  18. Dec 24, 2012 at 2:03 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    BJ failure. Check the pass. side, If its the same age as the dr. side replace that side also. I agree with Eric, get moog parts, still american made. Watch out for the chinese junk thats out there.
  19. Dec 24, 2012 at 2:53 PM
    hkdontoyotas
    hkdontoyotas Active Member
    I just replaced my lbj with moog from rock auto.com and they came with grease zerk fittings. was not to bad of a job to do if you have some minor mechanical experience.
  20. Dec 24, 2012 at 3:07 PM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    This makes me worried about mine... They been leaking grease for a while :cool:
