Catastrophic failure caused by lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Dec 24, 2012.
  1. Dec 24, 2012 at 3:13 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Isn't this a pretty widely known issue?
    Glad you're okay OP. I'd have everything swapped out with new BJs.
    Oh and Monte, do you mean the knuckle!? :brianr::D
  2. Dec 24, 2012 at 4:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    There was a lower balljoint recall on the 1st Gen Tundra covering up to 2005.
  3. Dec 24, 2012 at 8:37 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    x2
    OP, glad no one was hurt much, you may not like what I'm gonna say but here goes....
    I find it hard to believe that this suddenly happened, ball joint failures like this are due to neglect, it HAD to have driven & handled like shit for awhile before it sheered, luckily you were going slow when it finally signed off
  4. Dec 24, 2012 at 8:43 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Say what??
  5. Dec 24, 2012 at 8:45 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    That's not the lift. That's driver error. Your ball joint had been worn out for a long time.
  6. Dec 24, 2012 at 9:06 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    I always check mine for play mostly due to the first gen problems and the tundra problems. I usually squeeze the lowers with my large pair of channel locks and then lift up at the bottom of each front wheel when I do an oil change. You can definitely notice when they are loose.
  7. Jan 2, 2013 at 8:40 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    "All of the sudden, my car runs out of gas."
    No, your car was low on gas for at least 40 miles before it finally gave up. You just didn't pay any attention to it.
  8. Jan 2, 2013 at 2:18 PM
    chris66
    chris66 ( ͡°( ͡° ͜ʖ( ͡° ͜ʖ ͡°)ʖ ͡°) ͡°)
    dust
    CO
    2004 Prerunner
    bfg at ko2, method double standard
    hm that sucks. toyota replaced my balljoints according to a recall ... recently though i removed my strut and unbolted the lower ball joint and swaybar and after putting everything back together i have a little squeak .. not sure if i didnt notice it before or if it is new but now im scared :eek:
  9. Jan 2, 2013 at 2:30 PM
    selftaughtguru
    selftaughtguru Well-Known Member
    Aaron
    Grande Prairie, AB
    2013 Pyrite Dbl Cb Taco
    OME 885, NITRO 9000 & DAKARS, BLACK 'TRD' SKID PLATE, SMITTYBUILT NERF BARS, RIGID DUALLY & DUALLY D2 LIGHTS, AFE INTAKE, BAKFLIP G2 TONNEAU COVER
    Havnt seen one do that in quite sometime. I haven't looked closely to be sure but I'm thinking the load is transfered in the same manor as 1G. A design which requires a different method to check for play than your standard setup. Seen many worn out balljoints missed due to ignorance.
  10. Jan 2, 2013 at 3:22 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Ball joints are not hard to check, first look at the rubber grease cup that encloses the stem. Is it ripped ,torn or is it even there ?? After that if its damaged you can bet its dry of grease usually, with front of vehicle raised off ground grab the wheel at 12 o'clock & 6 o'clock & wiggle it there should be almost zero play, do the same thing side to side by grabbing the wheel at 9 & 3 (o'clock) Or if you see shiny metal below the rubber grease cup thats another indicator that a lot of wear has taken place as the ball is wearing away at the socket, this is really what you're looking for because the walls of the socket are getting thin, after that 1 hard bump or pothole too many & seperation takes place.....
    Check tie rod ends pretty much the same way..
  11. Jan 2, 2013 at 4:08 PM
    chris66
    dust
    CO
    2004 Prerunner
    Will definitely check in the morning. Only thing is my bjs were replaced last year
  12. Jan 2, 2013 at 6:03 PM
    scocar
    scocar hypotenoper
    See if your VIN was included in the LBJ recall. Mine was, and Toyota replaced them immediately for free, and aligned it. Just call a dealer and give them the VIN. If so, they should be doing this repair for you.
    A batch had a manufactuting defect, hence the recall.
    As other have said, several members have had the LBJ nuts come loose and the bolts come out, some hanging by a thread. Inspect regularly.
  13. Jan 2, 2013 at 7:13 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    My driver side lower ball joint failed me on my 96 in September of 2011, ball joint wasn't leaking nor was anything loose because I had recently checked all of them after I noticed my passenger side upper ball joint was leaking. It can happen without any signs, I had no vibrations and my alignment was perfectly fine.
  14. Jan 2, 2013 at 10:07 PM
    jetlag
    jetlag Member
    Jay
    SoCal
    Had the same failure on my 1996 Tacoma stock height. Recently installed Moog lower ball joint and it's forge steel, not sure if the stock/oem are forge or not.
  15. Jan 2, 2013 at 10:17 PM
    #35
    PcBuilder14
    Brent
    Southern New Mexico
    I couldn't tell, way to much damage...
  16. Jan 2, 2013 at 10:24 PM
    #36
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    They are all forged then detail machined - cheapest way to make them.
    1st gen Taco lower ball joint will pop out when it fails. Toyota inverted it for 2nd gens so the weight of the truck keeps the ball in the socket even when the joint wears out.
  17. Jan 2, 2013 at 10:41 PM
    #37
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    ^yep the design isn't the best b/c it is complete fail if the joint goes.
    i checked both my lowers a week ago by lifting the lca's and placing a prybar inbtwn the joint to get good leverage. my pass side didn't budge at all while my drivef moved a few mm with me pulling as hard as could on the prybar, but i think it is still good enough to last until summer time or spring break at least. i think they say more than 5 mm displacement at 50 lbs is a go for replacement.
    but i'll certainty be calling dealer to see if i can get replaced for free but doubt it b/c the mytoyota website which has my VIN has given me any eligible recalls
    we had a very bad ball joint on an '85 volvo and the car and steering wheel would shake excessively at a certain turning degree. OP did you notice any shaking at all?
  18. Jan 2, 2013 at 10:56 PM
    #38
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    did someone say BJ? :spy:
  19. Jan 3, 2013 at 10:27 AM
    #39
    KenLyns
    Belly of the Beast
    ^Grinding noises in a BJ is bad news. :eek:
  20. Jan 3, 2013 at 6:18 PM
    #40
    Rich91710
    Rich
    Los Angeles
    08 Base
    Unless it's....
    No... not that either....
