Catback exhaust
Discussion in 'Performance and Tuning' started by 2000SIG, Aug 10, 2010.
  1. Aug 10, 2010 at 11:46 AM
    2000SIG
    2000SIG [OP] Well-Known Member
    Would a 3.4 catback fit a 2.7 ?
    1ST gen.
    thanks
  2. Aug 20, 2010 at 2:19 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    cab size? pipe size? brand?
  3. Aug 21, 2010 at 1:10 PM
    2000SIG
    ext.cab borla,trd or magnaflow
  4. Aug 21, 2010 at 1:13 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I think the points where the cat back connects to the midpipe is different. I think the v6 mid pipe that has the cats is longer than the 2.7 and positioned a little differently and sets everything back for connecting. You could probably do it if you welded some tubing in between the rear exhaust and mid pipe.
