Catch Can for Oil Filter - V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco John, Feb 5, 2010.
  1. Feb 5, 2010 at 3:18 PM
    Taco John
    Taco John [OP] Well-Known Member
    Illinois
    4X4
    I haven't seen this on here and sorry if it is a repost, but I found one of the little bunge straps a really easy way to hold a soda can under the oil filter drain spout. Just hook to the tab and wrap around the filter mounting base and hook the other hook on the tab.
    Capt. Obvious and TacomaMike37 like this.
  2. Feb 5, 2010 at 3:20 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    thats a good idea, i just used the 5/16th tubing and ran it to the ground but +1 on the creativity
  3. Feb 5, 2010 at 5:50 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    ^^^x2
  4. Feb 5, 2010 at 5:55 PM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
    I should have used the bungee cord mod when i did mine. thanks for the cheap/free idea. +10
  5. Feb 5, 2010 at 6:00 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I used to actually use the old oil filter to catch the oil. Now I attach a tube and run it to my drain pan on the ground below.
    I like the fact that Toyota set it up like this. I've been changing the oil on vehicles since I was a kid, and this truck easily provides the cleanest oil changes I've ever dealt with.
  6. Feb 5, 2010 at 6:24 PM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I use a Corona bottle. Fits quite well.
    Shawn
  7. Feb 5, 2010 at 6:32 PM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    x 2 ... I liked the way Toyota did the oil filter drain too.
    FWIW, I had a 2007 Tundra and it was a nightmare to change with the oil filter cartridge & O rings.
  8. Feb 5, 2010 at 6:37 PM
    PA452
    Western PA
    Yep, growing up my parents went through a lot of Saturns. Some weren't too bad, but some were absolutely moronic. With most of them, there was no way around draining oil all over other parts when removing the old filter. And since you were draining onto other parts, there wasn't even a focused spot to put a drain pan, it ran all over the place.
  9. Feb 5, 2010 at 6:40 PM
    roy826
    roy826 Well-Known Member
    Mississippi
    2010 Prerunner TRD Sport DC
    Changing the oil filter on the 3.4L was no picnic. Man I hated that.
  10. Feb 5, 2010 at 7:35 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    My take on this was a little more involved. I added a small inline valve (petcock) like used on a motorcycle. I routed the hose to where my oil drain pan could be used.
    TacomaMike37 likes this.
  11. Feb 5, 2010 at 7:44 PM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    First service at the dealership and the tech left a water bottle under the hood to catch the oil. My next oil change is free.
  12. Feb 6, 2010 at 4:52 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    :eek:
    wow good thing it was any of his tools :smack:
    op good idea!
    I use the smaller empty powerade bottles, fits right in there nicely.
  13. Feb 6, 2010 at 7:06 AM
    braggman7
    braggman7 Well-Known Member
    Athens, GA
    '10 Double Cab TRD Sport 4WD
    Yeah, I just did my 1st oil change and honestly, I found the 5/16" tubing method kind of a pain. I'm going to just use a bottle or cup next time.
  14. Feb 6, 2010 at 7:44 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Defroster mod, Bilstein 5100s front, Adjustable Ranchos rear.
    I have always used a small plastic cup with a piece of coat hanger formed into a hook which holds the cup under the drain. It was the simplest method I could think of.
  15. Feb 6, 2010 at 7:59 AM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I bought some fuel line (3/8" I think), about 3 ft of it. I attached one end to the nipple under the catch can and ran it along the side of the radiator fan shroud to the bottom of the truck. Fully, extended, the hose will hang down about 4" below the skid plate. I zip tied it to points in the front frame spar so it wouldn't hit anything. At the end I put in a vacuum nipple and cap. When not in use, the hose can be tucked over the skidplate so it rests on top.
    All I have to do is grab the hose and let it dangle beneath the truck, move my catch pan, remove the vaccuum cap, and remove the filter.
    This really saves all the hand contortions and burning you have to do to get a container under the catch can.
    I'll post photos when I start my build thread! Hahah believe it or not my name is actually Satoshi. Not the same one as the grille mod guy, but it'd be hilarious if this mod became the Satoshi Catch Can Mod.
    Edit; oh wait...lol someone above had already come up with it. And here I thought I was clever :p
  16. Jun 20, 2017 at 11:17 PM
    TinkyWinky
    TinkyWinky Well-Known Member
    Does the catch cup come from the factory? I want to get one for my toyota land cruiser, it's always a pita taking off the filter and having oil all over my front axle.
    I can't even put an oil pan underneath to catch it because my axle housing is right under neath and oil splatters everywhere.
  17. Jun 21, 2017 at 1:11 AM
    TexasTacoLT
    TexasTacoLT Well-Known Member
    FT Riley, KS
    '14 TRD Offroad 4x4
    3" ToyTech Coilovers and AAL Total Chaos UCAs Bilstein 5100 Shocks Method 17" wheels 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert FJ Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders 48" LED light bar Smoked Tail-lights Tinted Front windows and sunstrip (15%) Bestop camper cover Bushwhacker fender flares (colormatched) 8-ball shifter knob Amber LED grill lights Debadged doors and tailgate WeatherTech floormats Blue Footwell lighting Sudued 'Merikan Flag door decals T-100 style tailgate decal Two way radio with whip antenna Warn 8000lb winch
    First time I changed the oil, I went to Autozone to pick up the oil and filter, then stopped by Taco Bell on the way home. I emptied out the big ass plastic cup that came with my meal and used that, it rests quite nicely right underneath the drain. Been using that same cup ever since, lol. Wifey almost threw it away once :crazy:
  18. Jun 21, 2017 at 1:19 AM
    12TRDTacoma
    12TRDTacoma Pulley Man ;)
    Roberto
    Concord, CA
    12 TRD Sport DCLB 4x4 Tacoma
    Supercharged
    I just use a styrofoam cup. It works. Lol.
    More than one way to skin a cat right?
    Mickeydog likes this.
  19. Jun 21, 2017 at 1:28 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sp
    2.5 inch lift; 5100's front; OME rear; Air Lift; dual batteries; Bestop bed cover; Nfab nerf steps; EBC rotors; Threadwright Claw MT tires; hood scoop LED light install.
    A 16-oz vitamin water bottle is held in place nicely by the lower water hose. I don't like using hoses cause oil remains inside and makes a mess when you store it, even if stored inside a zip loc bag. I do place a vacuum plug on the nipple so excess oil don't leak after removing the bottle.
  20. Jun 21, 2017 at 6:02 AM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Red solo cup. Fits like a glove and one of the radiator hoses keeps it from falling. Doing this for 10+ years now.
