Catch Can nay sayers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yzkiley, Nov 8, 2017.
  1. Nov 8, 2017 at 9:24 PM
    #41
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Yup. A good cookie indeed! Have it your way, and do what you want. I see no losers here. If the naysayers haven't wasted $40 on SOMETHING questionable along the line, I'd be surprised! And vice versa too!
    Yzkiley[OP] likes this.
  2. Nov 9, 2017 at 5:30 AM
    #42
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! Mine is for sale in the classifieds. :p
  3. Nov 9, 2017 at 5:36 AM
    #43
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. Our turbo saab and volvo had them. The factory was on version seven or so for the saab and they still weren't happy with it.
    The original owner of the volvo used dino oil. So, we had problems with the breather system later in life.
    Turbos are a very different beast when it come to crankcase breathing though.
    rlx02 likes this.
  4. Nov 9, 2017 at 5:44 AM
    #44
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Just don't be that DB at the track that doesn't empty his catch can pooring it all over the strip causing loss if traction. You always hate that guy.
    US Marine likes this.
  5. Nov 9, 2017 at 7:56 PM
    #45
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    #45
  6. Nov 9, 2017 at 8:01 PM
    #46
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    I don't know where the PCV is off hand on the V6 trucks but the way it hooks up is very simple.
    Output of PCV valve hooks to IN on catch can, OUT on catch can goes to intake manifold where the original PCV hose was plumbed to.
    Basically you are just intercepting the flow of blowby gasses and catching them.
    #46
  7. Nov 9, 2017 at 9:02 PM
    #47
    Dacon
    Danny
    Gilbert, Arizona.
    Sound easy IF the invisible PCV reveals itself. Also keep the PCV right? I don't see the point of remove it.
  8. Nov 10, 2017 at 9:22 AM
    #48
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Definitely keep the valve- it's a check valve so you don't suck things in.
    Also shouldn't there be a vacuum diagram under the hood somewhere (on a big sticker) that shows you where the PCV is, or have we stopped doing that...
  9. Nov 10, 2017 at 6:38 PM
    #49
    Yzkiley
    Yzkiley [OP] Well-Known Member
    British Columbia, Canada
    2016 MGM Tacoma Sport DCSB MT
    rain guards, hood deflector, oem tonneau, BFG ko2's, led lightbar behind grill, highlift jack mount side rail, husky Xact front & rear mats, bedrug, AFE cold air intake with scoop, TB spacer, Spec U exhaust, Hikari - lumileds Led's, any time backup cam and gps, OV tune 103B, TRD pro grille, Cali raised pod fog lights, ECGS needle bearing, Bilstein 5100's, Low range offroad 3-1 level kit, SPC light racing ctrl arms, spidertraxx 1.25in spacers, Ride right airbags, clazzio seat covers, carrier bearing spacer, diff drop spacer.....
    pvc is there and not easy to see. Place your hand on the hose in the diagram I posted and follow it. Basically it on the drivers side at the back of the motor. Its a bit of a pita to get the new hose on the pvc valve due to its location. Lube up the inside of the hose and ram it on, ha - that what she said:censored:
  10. Nov 10, 2017 at 8:13 PM
    #50
    rhouse181
    rhouse181 Well-Known Member
    2017 TRDOR DCSB
    Definitely would not use VW venturi PVC filters as an example of successful OEM “catch cans”... Some of the worst issues with carbon build-up on intake valves experienced by any manufacturer.
    A big issue for DI motors, but the very reason why Toyota went with the DI / port injection combo...
    Wonder the proportion of water to oil in that catch can?
    Paul631 and tonered like this.
  11. Nov 10, 2017 at 10:54 PM
    #51
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think the need for catch cans has grown, Engines now use ultra thin Oil and Low Tension Rings for better fuel economy but a side effect would be blow by.
  12. Nov 11, 2017 at 8:51 AM
    #52
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Another good point... but on the flip side, wouldn't 0w20 synthetic be the least prone to making gnarly deposits? Low viscosity and very little "funk" in the base oil stock to turn into a deposit.
    This thread is actually turning out to be a lot more thought provoking than I expected.:cool:
    stun gun, OmegaMan73 and CusterFan like this.
  13. Nov 11, 2017 at 8:58 AM
    #53
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    This may have been touched on already, but would having a catch can cause any issues warranty wise?
  14. Nov 11, 2017 at 9:13 AM
    #54
    shakerhood
    Southern Ohio
    I don't see why it would cause any warranty issues, but it looks easy enough to remove if you felt so inclined to before dealer service.
  15. Nov 11, 2017 at 12:46 PM
    #55
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    On most direct injection engines I would want a catch can since lack of port injection creates a valve issue. On ours, Toyota remedied that with the D4S port injection feature. Nice to keep the intake side clean, but not really going to do much with port injection cleaning, IMO.
    tonered and CusterFan like this.
  16. Nov 11, 2017 at 5:51 PM
    #56
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Think i might install mine tomorrow. Its been sitting around collecting dust for a while.
  17. Nov 11, 2017 at 6:22 PM
    #57
    T4RFTMFW
    T4RFTMFW Well-Known Member
    The answer is always maybe.
    trabo and 1bad2k like this.
  18. Nov 11, 2017 at 6:58 PM
    #58
    eurowner
    eurowner Duke Sky
    Scoty
    I ran a Provent 200 on my '94 K2500 Suburban 6.5 Turbo Diesel so the cold side of the turbo got the least amount of blowby going into the intake. It worked.
    1bad2k likes this.
  19. Nov 21, 2017 at 11:33 AM
    #59
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    Do the catch can help mitigate tailpipe smoke when driving up a steep grade (4x4 off-road situation)?
  20. Nov 21, 2017 at 11:52 AM
    #60
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No
    stun gun likes this.
