CATCH CAN vacum lines reversed! Did I F UP my engine?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JDKred, Dec 5, 2022.
  1. Dec 5, 2022 at 8:22 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    My Lips are Seals…..
    Rusty66, Junkhead and JDKred[OP] like this.
  2. Dec 5, 2022 at 8:24 PM
    JDKred
    JDKred [OP] Well-Known Member
    JD
    16 MT KDMax Tuned
    It sounds like this is a common issue with tacomas in winter.../shrugs...
    Not sure how water would have gotten in... I have never had this happen in winter before...
  3. Dec 5, 2022 at 8:25 PM
    vivid02
    Edwin
    SoCal
    OEM+
    Since you reversed the lines instead of vacuum , you were creating boost.
    :anonymous:
    Newton’s Third Law: Action & Reaction
    Whenever one object exerts a force on a second object, the second object exerts an equal and opposite force on the first.
    His third law states that for every action (force) in nature there is an equal and opposite reaction.
    JDKred[OP] likes this.
  4. Dec 5, 2022 at 8:38 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Most catch cans have a honeycomb mesh or steel wool separating the inlet and outlet. As the crankcase gas passes through the mesh or steel wool, it slows down and separates the oil from the air. The oil droplets then drip down into the reservior portion of the catch can. As long as the mesh or steel wool is above the reservoir, the catch can will work more or less the same regardless of which port is inlet vs. exhaust.
    The residue under the cap is normal, as @vicali linked.
    JDKred[QUOTED][OP] likes this.
  5. Dec 6, 2022 at 6:33 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    ^^^ This - the mesh should be on the firewall side of the orientation. Simple fix if you reversed the fixed connection setup.
  6. Dec 6, 2022 at 8:37 AM
    wj3v
    wj3v Active Member
    2022 TRD Sport
    Funniest thing I have read in a long time!
  7. Dec 6, 2022 at 1:13 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    You're absolutely right. I should have know TW would choose coddling over encouraging OP to rub a few brain cells together.
  8. Dec 6, 2022 at 8:04 PM
    JDKred
    JD
    16 MT KDMax Tuned
    Ya know.. it's funny... I thought asking questions was a way to learn... But hey, I'm just a coddled baby....
  9. Dec 10, 2022 at 10:00 AM
    JDKred
    JD
    16 MT KDMax Tuned
    Thank you to all who helped offer actual ideas to help.
    Got it all sorted.
    Thanks again! :thumbsup:
  10. Dec 10, 2022 at 10:12 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Since the empty nonfunctioning catch can didn't hurt your engine. Do you still think you need the catch can?
    Asking for a friend.
  11. Dec 10, 2022 at 11:14 AM
    JDKred
    JD
    16 MT KDMax Tuned
  12. Dec 10, 2022 at 10:08 PM
    Woodythebluetaco
    Woodythebluetaco Well-Known Member
    2016 Tacoma SR5 Blazing Blue
    Stacked plate transmission cooler Front: Custom Fabtech 2.25 Resi Coilovers, King springs, Eibach Tenders Rear: Fox 2.0 Resi, Custom OME Dakar Leafs, Caltracs Rebuilt 3.5
    The 3.5 produces an assload of blow-by. The ccv pukes up like a mother, too.
    It’s definitely worth it installing a catch can for both.
    JDKred[OP] and auskip07 like this.
  13. Dec 10, 2022 at 11:24 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Is this speaking as someone who doesn't have a catch can?
    I did my oil yesterday and pulled my catch can it wasn't "nothing" in the bottom of the can.
  14. Dec 10, 2022 at 11:26 PM
    auskip07
    Skip
    Atlanta, Ga
    But completely expected from someone who could screw up a catch can install right?
  15. Dec 11, 2022 at 6:10 AM
    #35
    Bishop84
    Bishop84 Well-Known Member
    I was suggesting he was checking too soon.
    It’s as a tech we check blow by from time to time, the new four cylinders actually have a recall where you check PCv operation. You can feel and see the blow by. The throttle plate is a good visual indicator, the v6 never gets nearly as dirty as the other engines.
    All engines have it, but I’ve always found Toyota v6s to have the least. I’ve only seen a couple with ring issues/ excessive.
