Caved And Got Billet Grill - Pictures
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tsilliker, Feb 14, 2009.
  1. Feb 14, 2009 at 8:38 AM
    tsilliker
    tsilliker [OP] Well-Known Member
    London, Ontario, Canada
    '05 SR5 V6 4x4 6spd
    Tundra wheels, Access roll-up tonneau, D-rings in front of bed floor, tinted glass in doors to match privacy glass, synthetic oil, Husky floor liners, fog lights, constant power mod for 12v plugs, heated mirrors, brake controller, billet grill, radio aux input mod.
    Well after admiring some of the Tacos here with billet grills, and recently seeing a Lincoln MKX with a nice chrome billet grill, I decided to make the leap.
    The 4-piece billet grill from eBay seller Goody4Less was US$120 + shipping. Reasonably priced and a quality item. They also have a 5-piece for those with the wart on the hood.
    http://myworld.ebay.com/goody4less
    This pic shows the various parts, along with my grill removed. Apologies for the quality of these "in-process" pics. I should have gone inside to get my Canon instead of taking pictures with my cell phone.
    To remove the grill, two plastic clips and two screws on the top of the grill must be removed. And two small plastic clips on the bottom need to be pinched or squeezed to allow the grill to come off. This took about 60 seconds for all 6 fasteners!!! The bottom fasteners stay in place upon removal of the grill and will snap back through the holes in the grill upon re-installation.
    The next step is to use a Dremel with plastic cutting attachement to remove the center crossbars of the original grill. Remove only the crossbars leaving the lip all the way around.
    Put the larger center billet portion into the opening. Press it in so that it is flush with the chrome outer trim. You will eventually feel it "bottom" and reach a flush natural position. A second set of hands is worthwhile to hold it in place while four holes are drilled through the mounting tabs into the inner black lip of the Toyota grill.
    I wasn't too happy with the screws and speed nuts supplied. I will probably replace these items with nuts and bolts along with a dollop of Loctite.
    I removed the Toyota emblem from the original grill by unsnapping three clips. I removed all but the two larger top tabs from the emblem to be able to mount it to the new billet grill. I used automotive "Goop" glue in generous amounts and applied it to the back of the emblem. I used zip ties to hold it in place. I will leave these on for a few days as it is cold and it will take a while for the glue to set up.
    continued in next message...
  2. Feb 14, 2009 at 9:16 AM
    tsilliker
    '05 SR5 V6 4x4 6spd
    That Goop glue dries clear and should work great for the very light emblem.
    Before putting the new grill on, I took some black spray paint and painted the end caps of the silver coloured air conditioning condenser unit. From installs I have seen here, this shows up behind and detracts from the look of the new grill. Several coats were required for me on this cold day. The paint ran after the first coat, exposing the silver colour again.
    This ends the cutting phase of the install. Every other part goes on without any further cutting. To mount the small outer pieces, however, a hole will need to be drilled into the waffle-pattern plastic inside each of those little holes. This takes little time.
    These two pieces are different. The hole in each little piece should go towards the center.
    The bottom portion that goes into the bumper is attached by two hooks and the supplied screws. The location of the grill piece is obvious and the fit was precise. There is no need to remove the factory plastic crossbars. The directions to mount this portion and the other pieces were pretty good.
    In my opinion the billet grill looks great with the chrome trim on my silver truck. I have seen some painted black or covered in the rough truck bed liner stuff on dark vehicles, and that looks nice, too.
    Here is a picture of the final product:
    The pattern looks like it has dark diagonal regions running through it, but that is a function of the camera. The look is pretty slick. The vertical supports in the grill are painted black and not very noticeable.
    The passenger window kinda looks like it is open, but that was a pattern left by the direction of the recent light snowfall.
    Very happy I finally did this mod.
  3. Feb 14, 2009 at 9:50 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    that looks great
  4. Feb 14, 2009 at 9:53 AM
    6shooter
    6shooter Well-Known Member
    portland, or
    06 sport........
    plenty.......
    i dig the shit out of your front plate...
  5. Feb 14, 2009 at 10:21 AM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
    nice :thumbsup:
  6. Feb 14, 2009 at 10:25 AM
    AK27
    AK27 Well-Known Member
    looks good man!
  7. Feb 14, 2009 at 10:30 AM
    stephbm6
    stephbm6 Well-Known Member
    West Jordan, Utah
    2006 TRD Double Cab
    Looks great!!! I want to do that to mine.
  8. Feb 14, 2009 at 10:54 AM
    tsilliker
    '05 SR5 V6 4x4 6spd
    Thanks, guys...(and gals)! And it only took a couple of hours.
    I think the front of the truck would also be improved by an aluminum front skid plate!
  9. Feb 14, 2009 at 10:58 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    looks great. I am thinking about doing the same setup.
  10. Feb 14, 2009 at 11:08 AM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Looks nice!
    "...Oh by the way...which one's Pink?"
  11. Feb 14, 2009 at 11:41 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Looks great, I have always liked that look.
    Now time for behind the grill light mod...............:D
  12. Feb 15, 2009 at 5:27 AM
    tsilliker
    '05 SR5 V6 4x4 6spd
    Well I'm not a likely candidate for this particular mod. I'm not partial to the "light behind the grill" look really. I'd rather have them out in the open loud and proud!
    Speaking of which, saw some guy in a pickup on the highway yesterday with four off-road lights on his rollover bar. He was driving with them turned on.
  13. Feb 15, 2009 at 6:16 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    truck looks good! First thing i thought of was that your window is open too..lol
  14. Feb 15, 2009 at 6:18 AM
    AK27
    haha thats the first time i've heard the scoop called a wart!
  15. Feb 15, 2009 at 10:02 AM
    sonjay
    sonjay Well-Known Member
    Looks good man! Love the plate. If you were closer to my coast you could have my aluminum skid.
  16. Feb 15, 2009 at 10:09 AM
    tsilliker
    '05 SR5 V6 4x4 6spd
    Why isn't it on your truck?
  17. Feb 15, 2009 at 10:13 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Looks good. Nice pic w/snow building up on truck.
  18. Feb 15, 2009 at 10:16 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
  19. Feb 15, 2009 at 10:22 AM
    sonjay
    Well I took it off and was going to paint it black, I have a black truck. Since taking it off I'm kinda liking it. the skid sticks out a bit and with it being silver on my black truck I'm just not a fan. I plan on getting some budbuild skids one day... maybe when our dollar is worth something?
  20. Feb 15, 2009 at 10:23 AM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Nice grill. Well done.
