CB Antenna Bed Rail Mount
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco_Dane, Apr 12, 2016.
  1. Apr 12, 2016 at 10:10 AM
    Taco_Dane
    Taco_Dane [OP] Member
    Arvada, CO
    '05 Tacoma TRD OR
    3" Toytec Bilstein coilovers, shackle flip and 6" shackles in rear, TRD Sport hood, 18" VTX wheels wrapped with 35" Nitto Ridge Grappler, PelfreyBilt sliders and front bumper, Homemade rear bumper and tiregate
    Been looking around for answers and coming up dry. I've got an 880 Bearcat and 4' firestik on the way. I plan to usa a HD spring, unless someone has good success with the med duty.
    I'm wanting to mount my CB antenna on the front rail of my 2nd gen,like pictured below. Is there a mount made for this or what do I need to make this work? Also how long a coax should I get? I was looking at the 9' firering but afraid it won't reach far enough. 18 however seems WAY too long.
    Thanks in advance for the help.
  2. Apr 12, 2016 at 4:34 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Look at "E-pay" - type in "CB Antenna Mirror Mount" - the heavy aluminum, angle bracket mounts will be there. Leave off the clamp side of the bracket and invent a piece to fit into the rail?
  3. Apr 12, 2016 at 5:40 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Just about any universal mount will work on the bed rails. I would avoid the fire ring coax. It's known to have corrosion issues. Go with the 18 foot coax and figure eight the excess.
  4. Apr 12, 2016 at 7:06 PM
    smd3
    smd3 Well-Known Member
  5. Apr 12, 2016 at 7:30 PM
    Taco_Dane
    Arvada, CO
    '05 Tacoma TRD OR
    Good to know thanks.
  6. Apr 12, 2016 at 7:35 PM
    Taco_Dane
    Arvada, CO
    '05 Tacoma TRD OR
    Radio Shack? I thought they were all gone.
    Planning center console install, sadly I don't have time to make a remote mount. Otherwise it would be going in the cubby hole.
    I measured today. 9ft should work.
  7. Apr 12, 2016 at 7:44 PM
    smd3
    There's a few left, I had to get a different end for the cable I bought.
    I made the mistake of asking the guy at the local "off road" shop to give me everything I needed to install the radio.
  8. Apr 15, 2016 at 2:55 PM
    Taco_Dane
    Arvada, CO
    '05 Tacoma TRD OR
    Well I ended up with a Uniden Bearcat 880, 4' Firestik with Firering, went with one I have to install the connector myself so I can cut to length and have something smaller to feed through the grommet. I'm just having to custom build my own bed rail mount. Relentless fabrication and Armortech were going to take too long. After all Cruise Moab is in just over 2 weeks. Should be able to install this weekend.
