cb antenna ground or not....
Discussion in 'Technical Chat' started by DIRT YOTA, Aug 3, 2010.
  1. Aug 3, 2010 at 8:07 PM
    DIRT YOTA
    DIRT YOTA [OP] Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Ok so I got my uniden 520 and am about to order a 4' firestick firefly and coax, stud mount and bracket. Guy at local shop said I don't need to ground the antenna that the metal mount will ground it when bolted to bed. I've heard otherwise. Also if I move mount say to tool chest that is mount In bed on top of bed liner, I will then need to ground antenna right. I searched this and kinda came up with different opinons.
    So for grounding would this cable and stud mount be best
    http://www.wearecb.com/store/firestik-mu8r18-18-foot-single-antenna-coaxial-cable-p-276.html
    http://www.wearecb.com/store/firestik-k4-stud-mount-p-248.html
    Or stick with this and just drill hole in metal bracket and run a ground from that....
    http://www.wearecb.com/store/firestik-k4a-stud-mount-p-249.html
    http://www.wearecb.com/store/firestik-k8a-18-foot-single-antenna-coax-cable-p-259.html
    Kinda a lot of links but want it right the first time. Thank you for any input that may help.
  2. Aug 3, 2010 at 8:12 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    I grounded the antenna and the cb itself!! Just to be on the safe side.
    Plus my father in law been using CBs and Hamm radios for over 30 years and he told me too. 
  3. Aug 3, 2010 at 9:25 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Ya radio part gets grounded for sure. Not sure which of the two ways I listed is better to ground the antenna. Leaning toward the cable with "fire ring" for the antenna coax side. How did u ground the antenna. Obviously to frame bolt or such, I mean on the antenna side.
  4. Aug 3, 2010 at 9:28 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Call your CB or antenna manufacturer - they are very helpful and will educate you for free on the concept of ground plane. Or you can get an antenna that does not require one.
  5. Aug 4, 2010 at 11:11 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Ya I got the ground plane down and I understand the concept of grounding...I was wondering if one of the two ways I showed/asked was better from peoples opinions or experiences. I'm gonna ground it either way. I just liked the stud mount that had the 259 coax connector. Basically what is a but setup, read that a lot of people had issues with their grounds.
