CB Antenna in Factory Antenna Location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hoverlover, Apr 2, 2018.
  1. Apr 2, 2018 at 1:17 AM
    hoverlover
    hoverlover [OP] Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Update: Before any tuning I was getting 3-3.5:1 SWR before any running in the 2' antenna. The mount has held up well, honestly a lot better than I expected. I've trucked right on through small tree limbs and brush and the antenna either bent out pushed it out of the way without moving the base or the mount.
    Mandatory CYA: Should you continue to read this, or attempt this modification, you do so at your own risk to yourself and your vehicle knowing and accepting that I cannot and will not be held liable for any injuries or damages.
    On to the mod!
    My factory antenna mount has wobbled since the day I bought the truck. It's always annoyed me and I've always wanted to get in there and fix it. Recently I snapped off my antenna at the stud and decided I'd do something different. I've had a multiplexor on my XJ for years and it gets excellent AM/FM reception and the CB communicates as far as I need it to. I'll admit, it's only a few miles, but that's more than I need and I am perfectly happy with that. I figured I also have been wanting to add a CB to my truck so I may as well give this idea a go.
    I've had a lot of interest about my CB antenna in the factory antenna location and have had a bunch of requests to do a write-up. This is my first formal how-to. Here goes.
    Parts required:
    RP-315 CB Antenna Mount
    Wilson 10" Stainless Steel Shaft
    Wilson 305-610 Heavy Duty Antenna Stud
    ProComm Im-AF Splitter (Inverse Multiplexor)
    At least M6x50mm bolts x 2, washers, nylon locking nuts, etc.
    Tap and die set.
    3' Male/female AM/FM antenna extension cord.
    1" heavy steel bushings or similar.
    9' (or your choice of length) Antenna Cable - 9' for center console mounting.
    CB of your choosing.
    Antenna of your choosing (I used a 2' FireStick FS II)
    First, pull the fender liner on the passenger side and the flare (yes, pull the flare, it'll make life easier later). You don't have to remove the liner, I just popped the back side out enough to access the antenna base.
    Remove the antenna and the silver ring at the base of the antenna. Mine was corroded and had to be cut off with a dremel. If yours is the same, pull the rubber protector off (save it for later!) and go to town. I cut the ring vertically in three or four places and worked it free. It's alright if you cut a little into the base, the rubber protector you should have already removed will hide any cuts.
    Once the top section of the antenna has been removed, remove the (I believe) 10mm bolt behind the fender liner holding the mast in place. You should also see the factory antenna wire routed through a large grommet. Once you have the mast free, pull the grommet out too. I simply cut the factory antenna wire near the mast and pulled it through the grommet. Hang on to that grommet, you'll reuse it too.
    Once you have liberated the mast and lower antenna mount, which is attached to the mast, you'll need to remove the factory antenna wire that is attached to its base. A dremel with a cut off wheel makes short work out this. You'll also need to separate the antenna base from the mast. I used a hand saw with a new blade and cut directly below the base where it meets the mast.
    Since we're cutting things with our shiny new blade. Cut the lower portion of the antenna mount off too. I cut just below the top two bolt holes and just above where it bulges out to clamp on things. Do the same for the other piece, it'll act as support on the inner fender later. You'll have to take apart the antenna base attached to take the mount apart, don't worry about reassembling it. We'll come back to that.
    Now, with a 3/8 drill bit (if I remember correctly it was a 3/8) or one that fits best, clean out the sheilding and the remaining wire inside the lower antenna base.
    I cleaned the corrosion off of the upper and lower antenna bases and painted them as well.
    Assemble the heavy duty stud, the 10" stainless steel rod, and the antenna mount like so.
    Note that the antenna mount LOWERS the antenna slightly.
    Using your die set, find the size that matches the threads on the extension rod and add another 1" or so more threads. I'm sorry, I do not recall what size the die was. Thread a nylon locking nut to the bottom of the new threads, then the factory lower antenna mount and feed it up into position. From here I got the lower mount into it's normal position in the fender and put the factory upper antenna base on the extension rod. I mounted the CB antenna to gauge where I should mount the CB antenna base inside the fender. I found, inside the fender, the perfect place for me.
    You can see in this picture again, with the 1" spacers, the base lines up perfectly with the factory antenna hole and with a good flat area to support the antenna base as well.
    Now the fun part. You'll either need a long drill bit or you'll have to get really creative. I, luckily, had a long bit. On the outside of the fender, if you're facing it from the side of the truck, remove the fourth little clip from the bottom up.
    This next image is taken looking through the hole that body clip fits into.
    After you have your antenna mocked up, ensuring it is not leaning to far fore, aft, port, or starboard, mark the holes in the base on the inner fender.
    DON'T DRILL YET.
    Inside the cab, remove the trim from the right side of the passenger floorboard area.
    Remove the top 10mm bolt holding all those wires in place and move them aside. I only had to pull that top bolt. It is bolted to the fender you're about to drill through. Pull the little tab out securing the carpet.
    Pull the carpet to the side. It doesn't have to be much. Measure up from the grommet hole inside and outside where your new body piercings are going. Verify you won't penetrate anything critical or otherwise. Also, it's not a bad idea to disconnect your battery at this point.
    Once you are certain, run your drill through the body clip hole in the outer fender to your marks on the inner fender. Take care not to bump the sides of the hole. No big deal if you do. You won't see it if you still use flares, but the body clip might be a bit loose.
    I added a bit of paint to the new holes to prevent corrosion and a ton of clear silicon to prevent leaks. You really can't use enough. Use the back side of the antenna mount that you cut earlier on the inside of the cab to help spread and support the load. Mount your antenna base with the 1" bushings like so.
    (I thought I used enough silicone sealant but had a minor leak during a heavy storm a few days later. I went back in and sealed some more and after washing the truck yesterday didn't have any further leaks.)
    I then shoved the CB antenna wire through the grommet, sealed it with more silicon, and ran the wire under my center console where I found a place to mount the multiplexor with an existing bolt and bolt hole. I had to use an antenna extension to reach my stereo.
    I also trimmed one side of a 3/8 grommet and used it to give the factory antenna base a more finished look.
    Once you get everything plumbed in the way you like it, go back and tighten the heavy duty stud, the antenna, and the nylon locking nut on the shaft. Verify all other fasteners are nice and tight.
    Account for your tools, replace the fender liner, the flare, and the interior trim. Reconnect your battery and tune in a radio station. If you have a CB, continue the install.
    That concludes the antenna portion of this install. I'm sure I'll make some tweaks here and there as time passes.
    If you guys have any questions or concerns, please shoot me a PM. I will update this thread from time to time with updates and pictures. Once I figure out which CB will fit my needs best I'll update with the SWR and if I needed to make any major adjustments.
    Thanks for taking the time to read this!
    -HL
  2. Apr 2, 2018 at 1:17 AM
    hoverlover
    Mostly Zip-Ties
    In an effort to continue the low profile-ish mods, here is how I ended up mounting my CB inside the dead space in the center console -
    Click here for more
  3. Apr 2, 2018 at 1:32 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Pretty damn slick. Good job OP.
    Slashaar and hoverlover[OP] like this.
  4. Apr 2, 2018 at 3:07 AM
    LostHusker
    LostHusker Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    Looks good man :thumbsup:
    hoverlover[OP] likes this.
  5. Apr 2, 2018 at 3:16 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    Thanks for the write up!
  6. Apr 2, 2018 at 3:19 AM
    Fuelman
    Fuelman Well-Known Member
    Winchester VA
    2014 Taco DCLB Sr5 4x4
    Ultraguage
    I see no reason you can’t get good SWR only drawback I see is the ground plane being weak to the right IE optimal location being center of vehicle.
  7. Apr 2, 2018 at 5:22 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    I really like this. Thank you for keeping me updated and tagging me.
    Does it still work as your AM/FM radio antenna too or only CB?
  8. Apr 2, 2018 at 6:51 AM
    hoverlover
    Mostly Zip-Ties
    No problem!
    With the multiplexor, the CB antenna doubles as an AM/FM antenna. Typically, the CB antenna will improve your radio reception as well. But it comes at a cost; you will sacrifice some CB performance and you cannot use the CB and your AM/FM radio simultaneously. I usually use a Bluetooth connection and I never need to communicate more than a few miles, so I am perfectly OK with the small sacrifice.
    Blais03[QUOTED] likes this.
  9. Apr 2, 2018 at 6:53 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Nice work Alex! :headbang:
  10. Apr 2, 2018 at 7:06 AM
    Blais03
    Nick
    Easthampton MA
    This is awesome. If i ever get a CB, this is certainly how ill be doing it.
  11. Oct 29, 2018 at 5:53 AM
    Blais03
    Nick
    Easthampton MA
    Still thinking I might do this. any issues now that youve had it for a little while?
  12. Oct 29, 2018 at 7:02 AM
    hoverlover
    Mostly Zip-Ties
    No, none so far and I've gone through some thick brush that bent the antenna back quite a bit. It's as sturdy as ever.
  13. Oct 29, 2018 at 7:35 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    That’s pretty much what we did with our FZJ80’s. There’s actually an already made kit that would cut out 90% of the fab work. It’s made for the 80 but I don’t see why it wouldn’t work for our Taco’s.
  14. Oct 29, 2018 at 7:47 AM
    hoverlover
    Mostly Zip-Ties
    I got the idea from an FJ, got a link to the kit?
    Blais03 likes this.
  15. Oct 29, 2018 at 7:58 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
  16. Oct 29, 2018 at 9:49 AM
    hoverlover
    Mostly Zip-Ties
    MolonLabeTaco[QUOTED] likes this.
  17. Oct 29, 2018 at 10:25 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I was a little to lazy for all that lol. Left the stock antenna and put the firestick on with it, had to modify the mount a bit for my needs. Held up great this summer in the bush, spring on the bottom gives it plenty of bendy.
    :cookiemonster:
    That the look of yours with only 1 antenna though o_O :thumbsup:
  18. Mar 19, 2019 at 6:16 PM
    hoverlover
    Mostly Zip-Ties
    After a few extensive wiring projects...
    732D65A7-D213-4141-B247-58D6515850A7.jpg E984E110-5949-4E29-9FDF-EAE951C5EAE5.jpg F8059BA0-23AA-4639-8920-A70341E6C3D7.jpg
    I haven't exactly had the motivation to install the CB that's been collecting dust in my garage. Since I'll be tearing everything apart again in a few days for the FJ transfer case, ADD delete/override switch, equalizer, and some other miscellaneous electrical projects I will take some time to install the CB as well and complete this project.
    Stay tuned.
    Pun intended :wink:
    BassAckwards, llamasmurf and Blais03 like this.
  19. Mar 19, 2019 at 8:43 PM
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    Nice work
  20. Mar 19, 2019 at 10:12 PM
    hoverlover
    Mostly Zip-Ties
    Thank you!
