Cb antenna mounting spot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Phils514, Jun 25, 2015.
  1. Jun 25, 2015 at 12:20 PM
    Phils514
    Phils514 [OP] Well-Known Member
    Phil
    Dcsb
    trying to look for cb antenna mounting options. I have a bed cover so it would be outside of the bed. Saw a bamf mount but could not find it again. Anybody have a link? Or other suggestions?
  2. Jun 25, 2015 at 12:30 PM
    bluedegeon
    bluedegeon Well-Known Member
    Colorado Springs, CO
    2017 TRD OR ACLB 4WD
  3. Jun 25, 2015 at 12:35 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    MadDaddy likes this.
  4. Jun 25, 2015 at 12:43 PM
    Phils514
    Phil
    Dcsb
    Thanks guys!
  5. Jun 25, 2015 at 12:44 PM
    bluedegeon
  6. Jun 25, 2015 at 12:48 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Both factory and drill. I believe it was just one hole I had to drill. The mount is also tucked back under part of the metal. I did the drilling for piece of mind, along with grade 8 bolts :anonymous:. I haven't noticed any rust around the area where I drilled.
    My only complaint is it can be a pain when trying to wax that small area behind the mount.
  7. Jun 25, 2015 at 1:01 PM
    Vanilla Thunder
    Vanilla Thunder Well-Known Member
    Vroom
    0625151248_resized.jpg 0625151248a_resized.jpg 0625151249_resized.jpg 0625151248b_resized.jpg
    Kind of made mine like a BAMF mount, uses factory holes/bolts. Pretty stable at highway speeds with no spring. Used electrical tape to ensure my paint doesnt get messed up from opening/closing the tailgate.
  8. Jun 25, 2015 at 1:03 PM
    Vanilla Thunder
    Vroom
    Don't judge me for the paint job on the bracket, I have no patience and didn't let the paint dry enough before i mounted it.
  9. Jun 25, 2015 at 1:21 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    I crafted a bracket for my magnetic mount antenna. I crafted a metal bracket - an inverted "L" shape, bolted to the bed rail. It sits just below the material on my soft cover and my magnetic antenna just "sticks" to it. I know it is good up to 65mph. SWR readings are 2.8 on channels 1 and 40 where mounted in the pic. On the roof, readings are 1.2 on channels 1 and 19.
    C.B. performance is significantly better with the roof mounted option and antenna is secure up to 80mph
    Both options allow for easy removal of the antenna. Roof mount for highway travel and soft cover mount for the trail[/GALLERY]
  10. Jun 26, 2015 at 1:53 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Mag mount on roof is the best mounting area.
  11. Jun 26, 2015 at 3:57 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Until someone takes it off the wrong way. And leaves some nice, long scratches as it drags along.
    Ask how I know.
  12. Jun 26, 2015 at 9:56 AM
    boomer6
    TN
    Tacoma TRD Offroad
    I put some 3m clear film between all my mag mounts and roof of truck . Been good since 2011.
    greeneggsnspam likes this.
  13. Jun 26, 2015 at 11:14 AM
    jbrnigan
    Midwest
    did the same thing, works great
  14. Jun 26, 2015 at 11:22 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    If only I realized that earlier.
    Alfred likes this.
  15. Jun 26, 2015 at 11:28 AM
    jbrnigan
    Midwest
    Egg man, if that's your truck in the picture, you're worried about a scratch or two???? LOL
  16. Jun 26, 2015 at 11:34 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    :anonymous:
    I did manage to get out the scratches on the roof. I fight a constant battle with scratches every few months. The 8 hours I spend working on polishing and waxing the truck is worth the fun I had getting them on there.
  17. Jun 26, 2015 at 11:38 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Mounted to a bracket on the Lightbar up front..
  18. Jun 27, 2015 at 6:07 AM
    G.T.
    G.T.
    CONUS
    I used the Relentless hood mount.
    But to those that are using the taillight location mounts that have shells. Do they interfere with the opening of your rear window?
  19. Jun 27, 2015 at 9:08 AM
    Pigpen
    Dan
    Northwest Montana
    This is my plan. I'm running a mag mount on the roof - only put it up there when I'm using it.
    Any negatives to this setup?
  20. Jun 27, 2015 at 9:38 AM
    G.T.
    G.T.
    CONUS
    The space below the mount is a bit shallow so I used a Firestick antenna and cable. The cable has what is called a FireRing termination on it making it fit easily. Other antennas and cables might not be as easy to deal with in that position. I have the Flippac camper so I made certain to add the spring to mine which allows the antenna to be moved to the side when the camper lid is open. However, as I'm kind of a nut for a clean windshield and having it allows me to move the antenna back and prop the passenger side wiper up. I would have added the spring to accommodate this after the first windshield washing had I not installed it already.
    I bought the mounts for both sides and while I have them both installed I've yet to add anything to the driver side mount. Thinking about a either a 2 meter antenna or a puck type GPS antenna.
