Cb Antenna mounts 35$ shipped
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Croth51, Mar 10, 2017.
Should I continue to produce these after sold
  1. Yes
    45 vote(s)
    91.8%
  2. No
    4 vote(s)
    8.2%
  1. Oct 31, 2017 at 12:59 PM
    #81
    Croth51
    Croth51 [OP] Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    That's sweet dude...
  2. Nov 1, 2017 at 6:20 AM
    #82
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    After a little time on the 3m wheel and some grinding at home. I'll sand it down and paint it this weekend. I'll keep ya posted.
    Croth51[OP] likes this.
  3. Nov 1, 2017 at 10:03 AM
    #83
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    I love how you made that look. Pm me so I can start doing that.. Also specs of your 3m wheel
  4. Nov 1, 2017 at 1:47 PM
    #84
    Brewboy5
    Brewboy5 Member
    Virginia Beach
    03 Tacoma Double cab
    Just got around to installing mine, mounted up perfect with the tailgate bracket and doesn't interfere with the tailgate or camper shell glass when its up.
    lucky13don and Jerry311SD like this.
  5. Nov 1, 2017 at 7:00 PM
    #85
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Glad it worked for you!
  6. Nov 3, 2017 at 12:18 PM
    #86
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    All painted. Just need to open up the mounting holes a little bit so I can get both bolts in.
    Should work out fine.
    Brewboy5 and Croth51[OP] like this.
  7. Nov 3, 2017 at 1:35 PM
    #87
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    They didn't line up?! That's the first thats happened mind to send a pic so I can see?
    Jerry311SD[QUOTED] likes this.
  8. Nov 3, 2017 at 2:36 PM
    #88
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    When I get back home I'll take a pic
    It's only off a hair a few passes with a rat tail file it will be ok.
    I had to run out and get my son from school.
  9. Nov 3, 2017 at 6:12 PM
    #89
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    Off just a hair..
  10. Nov 3, 2017 at 6:20 PM
    #90
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    super wierd... ill have to review the template... maybe is just getting worn out from all the copies... thank you a ton
  11. Nov 3, 2017 at 7:01 PM
    #91
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    Yea no big deal. Drill bits walk some time.
  12. Nov 5, 2017 at 4:43 PM
    #92
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    All mounted up good to go
    Thanks again!
  13. Nov 5, 2017 at 7:38 PM
    #93
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Love it!!! Thank you
