CB antenna on Relentless Fab hood mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oorah54, Jul 24, 2016.
  1. Jul 24, 2016 at 3:21 PM
    oorah54
    oorah54 [OP] Well-Known Member
    Darren
    Guyton, GA
    2015 Blue Tacoma Base
    Has anyone done this? If so, did you have to take off some of the powder coating to get your antenna to ground out, or did you use a separate wire to jumper to a grounding bolt?
  2. Jul 24, 2016 at 7:53 PM
    Porter707
    Porter707 Well-Known Member
    James
    Ohio
    2020 F-250 Powerstroke
    Got my Firestik installed on one, haven't been able to test it as I cut the FireRing end going through my Firewall and haven't re-soldered the connection yet.
    Once I stop being lazy and get it done I'll let you know. I believe I saw other posts with people saying they used the ditch light brackets and had to sand down the powder coating to get it to ground correctly.
