CB antenna wiring
Discussion in 'Audio & Video' started by Minnis12, Feb 24, 2013.
  1. Feb 24, 2013 at 6:05 PM
    Minnis12
    Minnis12 [OP] Well-Known Member
    Blanchard, La
    '09 Tacoma BASE 2.7L i4
    de-flapped, Pro-Flow Super V muffler, Pilot offroad lights with 7 color changing LED's, fog lights
    Mounted my cb antenna to my toolbox so It doesn't ground properly. I tried running a ground wire from one of the mount screws to the acres on the bed liner that screw into the bed (I put the connector between the screw and the washer). It's still not working properly. Any suggestions???
  2. Feb 24, 2013 at 6:08 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    wire it to a chassis ground.
    how do you know its not working right?
  3. Feb 24, 2013 at 6:09 PM
    Minnis12
    Blanchard, La
    Cause when I touch the antenna mount, it shocks the hell out of me. And the cb doesn't get very good reception.
  4. Feb 24, 2013 at 6:19 PM
    650H1
    Michael
    VA
    i wired my mount-ground to a bolt on the front of the bed behind the back of the cab.
  5. Feb 24, 2013 at 6:25 PM
    Minnis12
    Blanchard, La
    Alright I'll look at it. I have a mirror mount and I just mounted it on my box cause I didn't wanna drill into my truck. Where did you run your coaxial cable into the cab?
  6. Feb 24, 2013 at 6:27 PM
    650H1
    Michael
    VA
    there is a small rubber seal in the fl in front of the drivers seat under the carpet. i just zip tied it with the chassis all the way up. i mounted mine in the bed rail with a mirror mount.
  7. Feb 24, 2013 at 6:29 PM
    Minnis12
    Blanchard, La
    Could you post a picture of how you mounted that?
  8. Feb 24, 2013 at 6:41 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    It takes much more than a good ground to make a CB work correctly. You need a 'good' antenna, the correct cable (5ohm 58 or 59 depending on your application), a good ground, a properly powered radio, no kinks or slack in wire, and a properly tuned antenna using an SWR. Keying the mic on your radio before all this is done can severely damage your radio. Have to do things right otherwise it won't work. Its nearly impossible to know if your ground is bad without an SWR.
  9. Feb 24, 2013 at 6:51 PM
    Minnis12
    Blanchard, La
    I don't have a tunable antenna but it is a decent fiberglass one. And my radio is also decent. It's all good parts I just need to get it tuned right I guess. I haven't need the mic cause I haven't picked up anyone talking. Just static and when I adjust the SQL it's just silent. And I live by a highway.
  10. Feb 24, 2013 at 7:00 PM
    Minnis12
    Blanchard, La
    Never mind. To time my antenna I need an swr meter and I need to trim it 1/4" at a time until channels 1 and 40 match up on the meter.
  11. Feb 24, 2013 at 10:11 PM
    Swordknives
    Swordknives mmm Tacos
    South OC CA
    2013 Dbl cab LB v6 SR5
    To test for a ground use a miltimeter. You can find them at lows or home depot for $20. I would suggest taking your set up to your local radio shop for help, as they can help you tune and troubble shoot.
    Google and search are your friends, google tuning a cb antenna and you will learn more than you ever thought you could.
  12. Feb 25, 2013 at 11:21 AM
    ProForce
    Anthony
    Alaska
    Yes a DMM will confirm if you have ground or not, but only an SWR will tell you if your ground is sufficient enough for good operation of the radio.
    And OP, I do recommend searching for this stuff online as well. Go to the Firestick website and check out their FAQ section. Every question you could ever have plus more.
    If your not comfortable or knowledgeable enough, take it too a shop as suggested. These things require special tools and knowledge otherwise you can/will destroy a brand new radio in seconds.
  13. Feb 25, 2013 at 5:49 PM
    Minnis12
    Blanchard, La
    My great grand father has an swr that I'm gonna use when I get a day off. Doesn't seem too difficult. Just understand what it is that your looking at and what your trying to find.
  14. Mar 4, 2013 at 7:11 PM
    Minnis12
    Blanchard, La
    I got another question if anyone is still checking, i need to run my Coax through the rear wall behind my seats. i found where to put it but the connector wont fit through the slot. if i cut it to put it through then splice it back together, will that cause any problems with my signal cause ive always heard NOT to shorten the wire but im not shortening it, just cutting it for a few minutes.
