CB coax cable
Discussion in 'Audio & Video' started by josh3972000, Mar 16, 2009.
  1. Mar 16, 2009 at 4:00 PM
    josh3972000
    josh3972000 [OP] Well-Known Member
    kentucky
    02 dbl cab TRD
    Where is the best place to run the coax cable through the cab, into the bed? Any answers will be greatly appreciated. Thanks.
  2. Mar 17, 2009 at 1:37 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    There are some rubber gromets at the back of the cab, between the bed and the cab. I poked a hole in the rubber and shoved the cable through it. I am adding a connector to the end after running the cable. This allows for the smallest hole possible, and the rubber gromet holds tight around the cable to make a water tight seal.
    I can post pictures if you want.
  3. Mar 23, 2009 at 2:33 PM
    DDD
    Derek
    Santa Clarita, CA
    OK, ok, I won't make you beg. Here are the pictures.
    Here is the grommet that I am going to use.
    I pulled out the grommet and used a sharp tool to poke a hole into it.
    I shoved my needle nose pliers through the hole.
    And grabbed a hold of the wire.
    Slide the grommet over the wire.
    Finally put the grommet back into the hole.
    Its water tight and you don't have to drill any holes in your truck. Now I ran the cable under the right rear door floor panel to the center compartment. There is already a channel with wires under that floor panel with room for 1 more wire...
    Naveronski likes this.
  4. May 25, 2009 at 8:38 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Nice pics thanks.
  5. May 25, 2009 at 9:41 AM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    There are also several of those plugs on the floor of the truck that you can use. Just get under your truck and start looking for one that is near you want to bring the wire into the truck.
    Good pics and techniques.
  6. May 25, 2009 at 9:48 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Cool thanks.... now I won't have the wire sticking through my sliding window...
    Where did you mount your antenna?
  7. May 25, 2009 at 10:13 PM
    DDD
    Derek
    Santa Clarita, CA
    On the bed rail behind the window. I cut a truck mirror antenna mount to fit.
    Similar to this guy...
