CB drop, diff drop and axle shim questions
Discussion in 'Suspension' started by Fox2011PM, Feb 12, 2013.
  1. Feb 12, 2013 at 2:54 PM
    Fox2011PM
    Fox2011PM [OP] Well-Known Member
    Texas
    '13 DCSB 4X4 PYRITE MICA
    5100s ON ALL 4 CORNERS, TOYTEC/EIBACH COILS, TOYTEC TOP PLATES, DEAVER 1.5" AAL, 3 DEGREE AXLE SHIMS, CB AND DIFF DROP, LIGHT RACING UCA's
    I received my lift a couple of days ago and need some opinions. I have a 2013 DCSB TRD OR 4x4. I got the 5100s x4, with Eibach's set at .85, and a Toytec 2" AAL. I know that several people are getting different results from installing these. I want to obviously have zero vibes if possible. I also don't want to waste time installing any of these options if they are not needed. The kit came with the shims, the CB drop and diff drop. Any thoughts/advice greatly appreciated!
  2. Feb 12, 2013 at 7:24 PM
    coseng
    coseng Well-Known Member
    Grove City, PA
    2011 TRD DC
    OME 885x front, Dakars rear, LR UCAs, ECGS bushing
    I am pursuing the same outcome. No vibes.
    I have a full OME kit, 885x on the front with driver side trim packer and no top plate spacers. LR UCAS, Dakar pack on the back.
    Before I put the lift on I installed the ECGS bushing in the front diff and ran it for a week at stock height to ensure I had a good installation.
    The next weekend I installed the rest of the components.
    I did put on a front diff drop although most would recommend against it.
    In the rear I utilized steel three degree shims under the Dakars and 3/8" spacers at the center carrier bearing.
    This set up resulted in almost no perceivable vibes, but I am very picky. I think I can still feel something between 25 and 30 mph. It is VERY slight and I tried to just get over it, but I haven't. So.....I ordered. 1 1/2" carrier bearing drop from beefed taco. I am hoping this will make the truck vibe free.
    Either way I am enjoying the manners of the lifted truck very much.
  3. Feb 12, 2013 at 7:31 PM
    MJM777
    MJM777 Well-Known Member
    N.E. Ohio
    2012 DCSB 4x4 Sport
    Sub'd
  4. Feb 12, 2013 at 10:04 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Have you given it a try without the shims or spacers? If not it might be worth a try before installing the carrier bearing drop. Many people with the same lift get no vibes if they do not install those options.
  5. Feb 12, 2013 at 10:13 PM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2006 DC SPORT 6MT
    885's, OME Nitros, AP 3" leafs, DTLT's, Magnaflow Exhaust, TRD SS, AFE prodry S, URD Maf Cal, Exedy Clutch, URD TOB, Bhlm, AP winch bumper, Daystar 9" lights, OEM roof rack, Yakima fairing, Bed & rock lights, Sony Sub & Amp, 48" Hi Lift, 4X sliders,
    The CB spacer and diff drop didnt do anything for me so I took em off. The 3* axle shims, I highly recommend. They fixed my vibration issue. This is with 3.5" rear lift
    Been lucky so far that my front diff bearing is still holding up.
  6. Feb 13, 2013 at 4:01 AM
    coseng
    Grove City, PA
    2011 TRD DC
    I didnt try the lift without any corrective components unfortunately. I don't have a baseline to compare to other than how the truck drove pre-lift.
    I'm sure most would classify my truck as 'vibration free' as it is. I unfortunately am very particular and cant leave well enough alone. It won't hurt to try the stock placement of the carrier bearing drop. Thanks.
    In my opinion from all the reading I've done here, a new bushing and axle shims shold be considered If your planning on lifting your truck. These consistently seem to produce the most positive results for members. I don't think the brand of kit chosen matters much, only the amount of lift achieved. Lastly, individual tolerance will effect everyones perception of the outcome. Like I stated, my issues are very very slight and may be considered non existent by someone else.
  7. Feb 13, 2013 at 12:45 PM
    penguins_cc
    Will
    Bellevue, WA
    ^^^ Cool. Good luck with it all. There's a ton of threads about vibrations - so much information to wade through. I thought I had a very slight vibe originally but then wasn't sure if it was the lift or the result of switching to new A/T tires. Now I don't notice a thing and not sure if there was something to begin with.
