CB drop install help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VooDoo, Aug 2, 2011.
  1. Aug 2, 2011 at 9:40 AM
    VooDoo
    VooDoo [OP] More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    I'm installing my OME cb drop purchased from toytec and have a noob question.
    The kit comes with the spacer, bolt, flat, and locking washer.
    I'm having trouble finding out what order the spacers should go in.
    Should the flat washer be the one closest to the ground? (the first one touching the bolt head) or should it be the locking?
    thanks in advance!
  2. Aug 2, 2011 at 9:52 AM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    bump
  3. Aug 2, 2011 at 10:04 AM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    anyone?
  4. Aug 2, 2011 at 10:09 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's, Pioner AVH-2300NEX w/backup camera, SCT X4 Tuner.
    I don't have experience with that particular kit, but I know that in general you always want the lock washer between the load and the bolt head/nut. So you want the lock washer to be the one up against the bolt head.
    Hopefully someone with first hand experience can either confirm or correct this.
  5. Aug 2, 2011 at 10:18 AM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    Thanks for the info :thumbsup:
  6. Aug 2, 2011 at 10:59 AM
    kb1jop
    kb1jop Well-Known Member
    Rick
    Springfield, MA
    2010 Barcelona Red 4WD DCSB 6-Speed SR5
    Factory Towing Package Factory Roof Rack OEM Bed Mat Trifecta Tri-Fold Tonneau SeatSaver Custom-Fit Seatcovers WeatherTech Custom-Fit Floor Mats Block Heater: http://www.metrotpn.com/ProductDetails.aspx?CollectionID=13&ProductID=191&SortIndex=9
    In general, I believe the lock washer goes on the NUT side. The bolt head is already "locked" to the bolt.
  7. Aug 2, 2011 at 11:05 AM
    Maticuno
    03 F250 CCSB
    True, I would put the lock washer on the nut side in that situation. But when you are putting a bolt into a threaded bracket to where there is no nut, I would want the lock washer on the bolt head.
