CB fuse box power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fau8823, May 18, 2011.
  1. May 18, 2011 at 7:59 AM
    fau8823
    fau8823 [OP] Well-Known Member
    Tom
    Hampton Roads, VA
    2010 Tacoma Sport 4x4
    Tint-20%, Kenwood 2 meter radio, firestik 2 meter antenna on a BAMF tailgate mount, Extang Solid Fold , Pioneer bhs-3500 HU, clazzio leather seats, Scangauge II
    Hey everyone!
    I gotta claim ignorance on this subject. I just ordered my Cobra 75 with all the needed accessories and antenna from Right Channel. I know how I will mount my antenna and route all the wires. My only question is powering the radio from the fuse box. What do I need to purchase to accomplish this? I don't want to connect it directly to the battery.
    Any assistance would be greatly appreciated! Thanks in advance!
  2. May 18, 2011 at 11:51 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    2002 Sliver-ade-o 2008 P71
    Yes
    You will need an "add a fuse". They should have them at Radio Shack. Direct wiring to the battery will give you the best perforance and is super easy.
  3. May 18, 2011 at 12:05 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    or a mini fuse tap.
  4. May 18, 2011 at 1:50 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    Add-a-fuse
  5. May 18, 2011 at 2:03 PM
    fau8823
    Tom
    Hampton Roads, VA
    Thanks for the info and the pic! I think I'll just use a fuse tap, as I haven't added any fuses to my fuse box yet. There has to be an open slot. Will the fuse box top still close properly?
    I dont want to run the wires directly to the battery, as I want to avoid any possibility of a fire hazard.
  6. May 18, 2011 at 6:02 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Run power and ground to the battery to prevent noise. Abs noise is so hard to get rid of
  7. May 18, 2011 at 6:14 PM
    lowinhz
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    A fuse is required no more tha a foot away from the battery rated at what the cb is rated for
  8. May 18, 2011 at 7:12 PM
    fau8823
    Tom
    Hampton Roads, VA
    That's why I wanted to hook the power up to the fuse box. That would accomplish that if I used a mini fuse tap, correct?
  9. May 19, 2011 at 6:55 PM
    lowinhz
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Depends on the side of the fuse that has the power.with a tap you have to use a test light to find out which side is hot and which is not the tap will go on the not hot so it can be protected with that fuse. But ground it at the battery if anything else.
  10. May 20, 2011 at 8:04 PM
    fau8823
    Tom
    Hampton Roads, VA
    Ugh!!!!! I tried installing it tonight with the add a fuse, using the fuse block behind the coin tray. No power at all! Could it be from an improper ground? Or is it something else? I tried using a bolt behind the kick panel as the ground for the radio. HELP!!!
  11. May 20, 2011 at 8:15 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Look everybody has been telling you to run the wiring to the battery. Absolute best way to do it and it's super easy.
  12. May 20, 2011 at 8:17 PM
    fau8823
    Tom
    Hampton Roads, VA
    1. The wires wont reach. Way too short.
    2. I don't want to punch a hole in the rubber gasket on the firewall to get them through.
    3. I want the fire protection of using a fuse.
  13. May 20, 2011 at 8:39 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    1. extend them using a butt splice
    2. No need to punch a hole. Run them through the firewall behind the fuse box in the cab. I run my CB, HAM, PIAA Aux lights, and LF light switches through the same hole. Get a wire hanger, carefully thread it through the hole from the engine bay, use some electrical tape and tape the wire onto the hanger. Now using the hanger like a huge needle, pull the hanger back through the firewall and presto, wire is through the firewall.
    3. So put an inline fuse, or add your own auxiliary fuse box. Thats what I did. I would rather fuck up an auxiliary fuse box than a stock one. The stock ones cost a whole hell of alot more.
  14. May 21, 2011 at 3:42 AM
    fau8823
    Tom
    Hampton Roads, VA
    Back to Autozone this morning it is then! What amp of a fuse did you buy for the inline fuse box? Thanks...
  15. May 21, 2011 at 6:48 AM
    MrGrimm
    Dean
    Wisconsin
    See build page
    Your CB should have had an fuse with it unless you bought it used and the original owner cut it. What brand and model of CB do you have?
  16. May 21, 2011 at 1:35 PM
    fau8823
    Tom
    Hampton Roads, VA
    Cobra 75. Install complete and works great. Thanks for the info. You were right. Should've went from the battery from the get-go. I bought the extra wire, and an inline fuse adapter also.
  17. May 21, 2011 at 5:26 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    Good to hear. Don't forget to get the SWR checked.
