CB install Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steace24, Aug 7, 2015.
  1. Aug 7, 2015 at 4:05 AM
    Steace24
    Steace24 [OP] Member
    Hey TW need some advice. I have installed the coax run for the antenna and mounted the CB (Midland 1001LWX 40 Channel) now I need to get some power to the unit. I would prefer to run the line to the battery but need some help with what materials are needed ie What gauge wire should I run? and What type/amperage of In-line fuse should I use close to the battery?
    Also if Add a fuse in the coin tray fuse panel is easier please let me know. Take me to school!!!
    Thanks
  2. Aug 7, 2015 at 7:52 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    CB radios use very little power maybe 5 watts or so. 12 wire is plenty
    Always connect the fuse close to the battery as possible inline fuse. Yes I would connect directly to the battery. I have ham radios in my car 50 watt no problem. Good luck. I use a thru the glass antenna made by Larsen it works great.
