CB install help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trucko, Mar 21, 2017.
  1. Mar 21, 2017 at 2:42 PM
    Trucko
    Trucko [OP] Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    I just purchased a BAMF CB mount for the back passenger side of the truck above the rear tail light. I want to run the CB cable to the cab of the truck. Is there a firewall hole in the back between the bed and cab or underneath somewhere. I have an 05 DCSB. Any pictures of others who have done this would be appreciated. Thank you TW.
  2. Mar 21, 2017 at 2:53 PM
    Spintly
    Spintly Well-Known Member
    Greg
    Home of the Groundhog
    85 Single Cab Pickup & 2000 911
    There is a wire loom under the driver seat that you can put the antenna cable through. Look underneath your truck and you'll see it. You can run the cable from the CB through this hole along the frame rail and behind the passenger side taillight.
  3. Mar 21, 2017 at 2:54 PM
    Spintly
    Greg
  4. Mar 21, 2017 at 3:13 PM
    Trucko
    2005 Tacoma
    Thanks this is a great start. 18 feet should be long enough correct?
