CB mounting help
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoman101, Oct 20, 2009.
  1. Oct 20, 2009 at 2:50 PM
    tacoman101
    tacoman101 [OP] Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    i just got myself a cb from a friend and just wanna see how some people mounted theirs in their truck. I got a first gen, i don't know if the interoir of these is dramatically differnt from a newer truck, but if you wanna post pics of your second gen with the cb mounted, this would be great too:D thank in advance
    Also, for the people that ran the cord through the back window (i think most) does your back window shut all the way, cuase mine doesnt. is their a way to get it to shut all the way
  2. Oct 20, 2009 at 2:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    here is mine.............mounted in the stereo console trim.....in place of the ash tray..
  3. Oct 20, 2009 at 2:58 PM
    tacoman101
    scott
    vermont
    thanks for such a quick reply, but mine is a little bigger, so i won't fit in that little pocket:mad:
  4. Oct 20, 2009 at 2:59 PM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    No help mounting, but...Get an SWR meter, and use it to adjust your antenna after you've decided where the final antenna location will be (if you move the antenna, you'll need to re-adjust). Also, read the instructions for the antenna. I just put a CB in my bus, and the antenna called for 18 feet of cable between the antenna and the CB. I could not get the SWR reading right without the extra cable. i believe that if you don't match the antenna you can damage the transmit circuit. Spend a couple extra bucks and get an adjustable antenna- they have a threaded part to adjust. The cheaper ones must be trimmed, and there's no going back!! Pretty sure you can't use the meter in the CB, buy or borrow an external meter. Shop around at truck stops and you should find one for $15-20. Or see if you can borrow one.
  5. Oct 20, 2009 at 3:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ah......will it fit in the center console?
  6. Oct 20, 2009 at 3:15 PM
    tacoman101
    scott
    vermont
    like how?
  7. Oct 20, 2009 at 3:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    depending on the size.......it may fit in the bottom console.....outta the way of everything, and outta sight. it will mount up and down...when you open the console, you'll be looking at the face of it.
  8. Oct 20, 2009 at 4:05 PM
    tacoman101
    scott
    vermont
    i'll see if it'll fit, but i got chords that i have to plug into my imput
  9. Oct 20, 2009 at 4:09 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    there are 2 rubber grommets at the back side of your cab that you can run the cable thru...theyre located in the storage compartments in the xcab :thumbsup:
  10. Oct 20, 2009 at 4:16 PM
    tacoman101
    scott
    vermont
    huh, i'll have to go check those out
  11. Oct 20, 2009 at 7:50 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    And you may have one big grommet underneath the driver's seat. I used that grommet to run my coax cable out of the cab in my 03 double cab, but don't know if the Xcab has the same grommet. I zip tied the coax underneath the frame and brought it back up between the bed and cab.
    I use a small hand held ham radio (cup holder mount) so I don't have any input for you on location.
  12. Oct 20, 2009 at 8:01 PM
    s2kvtak
    s2kvtak Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    what kind is that? thats perfect! also how much did it cost? looking to spend as little as possible so ill probably be going to a pawn shop, but if the price is good, then ultimate placement may overide cost
  13. Oct 20, 2009 at 8:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its a Cobra 19 Ultra III..............and they run about $40 or so.
    midland also makes some decent ones like this...bout the same size/price as well.
  14. Oct 20, 2009 at 8:07 PM
    JimBeam
    JB
    2015 Tundra
    uniden makes one about that size too
  15. Oct 21, 2009 at 4:29 AM
    tacoman101
    scott
    vermont
    thanks for all the help guys, i'll be mounting it today
  16. Oct 21, 2009 at 1:29 PM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    Hey Scott, Post some PIC's after you get the CB mounted. I still haven't put mine in yet. Need some ideas....;)
  17. Oct 21, 2009 at 2:43 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    x2
  18. Oct 21, 2009 at 2:59 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i saw that model at wally world on sale for $30.94 NICE!!!
  19. Oct 21, 2009 at 4:53 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
  20. Oct 21, 2009 at 4:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    damn!!!!! good price there man!! i saw it,for a lil higher, at northern last night.
