CB Preference-which is the best?
Discussion in 'Audio & Video' started by gryllswannabe, Jul 16, 2011.
  1. Jul 20, 2011 at 11:09 AM
    #41
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    I got it from rightchannelradios.com
    Make sure you get a heavy duty spring for it. I had a medium spring and the antenna was bouncing off my windshield on the highway. The HD stiffens it right up with enough give when you hit obstacles.
    (I'm digging the James May icon, BTW)
  2. Jul 21, 2011 at 1:10 AM
    #42
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Uniden 520 proxl with 4' firefly firestik and I love it!
  3. Jul 21, 2011 at 2:34 AM
    #43
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I have a cobra 29ltd classic with bigger galaxy finals and a connex board(echo and reverb) I run that threw a 200 watt kicker and out a Wilson magnet mount antenna. I have 3 different astatic mic's. My favorite being a camo edition noise canceling mic.
    I have my radio mounted under the driver seat with an external speaker mounted in the cubby in front of the cup holders. My mic hangs from a gear keeper that's hooked to the rear view mirror for easy access.
  4. Jul 21, 2011 at 8:13 AM
    #44
    Nolawall
    Nolawall "And there I was just minding my own business"
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    6" Fabtech Suspension Lift. K&N Air Filter Cobra 18 CB with 2 3' firestik II antennas
    You guys that put the CB where tha ash tray is? I see it sticks out a little. Is that as far as it will go in there?
  5. Jul 21, 2011 at 8:31 AM
    #45
    Ripcord
    Ripcord KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    It fits farther back if you buy an L-joint for the coax cable. Thats what I did.
  6. Jul 21, 2011 at 2:31 PM
    #46
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Can you take a picture of the Radio and the L-bracket. Just interested in doing this saame thing.
  7. Jul 21, 2011 at 2:34 PM
    #47
    Ripcord
    Ripcord KM6PIM
    Jim
    Hard to tell from the pic, but the front of the CB sits flush with the radio trim face.
  8. Jul 21, 2011 at 2:43 PM
    #48
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Thanks man that is a great set up. Looks really clean. Is that a bracket that is holding the CB in there or do you just slide it in?
  9. Jul 21, 2011 at 9:37 PM
    #49
    DIRT YOTA
    Cory
    Camarillo, CA
    Yup I put the right angle connector also, mine is nearly flush. I just made a custom bracket and didn't want to re mount after I was done. I could have slide it back a bit.
  10. Jul 21, 2011 at 9:41 PM
    #50
    FoundOffRoadDead
    FoundOffRoadDead whiptastic handling
    Shamus
    Walnut
    Ford
    i like it. well i think the bigger the better. Photo0051_298f4a095b1aa6056b2ca03c9a57770c39209832.jpg i like mine a whole lot!!
  11. Jul 22, 2011 at 2:18 AM
    #51
    gryllswannabe
    gryllswannabe [OP] Well-Known Member
    Larry
    NC
    "Cherry" Speedway Blue 2010 Taco
    None yet
    Some good ideas out there. Thanks for all the input guys. Nolawall, what is it about the DXIV that you like so much more than the previous units owned?
  12. Jul 22, 2011 at 5:32 AM
    #52
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
  13. Jul 22, 2011 at 6:40 AM
    #53
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    The cobra 19DXIV was one that i used when I did alot of trail riding when i had my jeep. The biggest thing was when i got it peaked and tuned it ran at a higher power than all the CB its size. The PA system was outstanding for whatever i needed it for at the time. It also took abouse. My jeep got wet lots and it didnt skip a beat. So I am sold on the cobra products for CB. My dad had a cobra 29 with a 300 watt leaner(AMP). It has a lot of power and just a great compny for radios. They are a little more expensive but you get what you pay for. If you dont care bout the PA system and rather weather. Cobra has a another radio that has lots of features that the 19 doesnt have. It has NOAA weather and scan as well. So for the sizw that we need in our trucks these two radios are what I plan to use when i finnaly get my stuff installed. I have only had my truck for about two weeks and I am trying to get other issues fixed so I can get started on my upgrading stuff and installing. By the way a peaked and tuned 19DXiV will run about about 6 to 7 watts. Thats damn good for a small radio like that. on cool dry nights you can talk for miles and hear for miles. I have don it up to 30 and maybe farther with mine in my jeep. Just my 2 cents
  14. Jul 22, 2011 at 3:50 PM
    #54
    gryllswannabe
    Larry
    NC
    None yet
    Great info man, thanks...that Midland looks pretty nice too!
  15. Jul 22, 2011 at 4:34 PM
    #55
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    What:
    Midland 75-822
    Wilson 4' flex
    Why:
    The Midland has a slide-off base that allows in-cab mounting and portable use in seconds, which appealed to me. It is also feature-packed for the price, main points being NOAA weather, scan (press a button, the unit scans through channels until it finds people talking), and the ability for dual-watch (swaps back and forth between two channels so you can monitor both).
    However, there are some negative points as well:
    -speaker could be louder. I crank it to the max and drive with it in my lap with the radio off and windows up. I don't have anything to compare to, maybe all units are this quiet? I hope not.
    -buttons aren't lit, small, and there's a lot of them. This means you won't use half those fancy features
    -I find it more natural to have a traditional unit with controls in a set place. With this, I tend to fish around until I find the unit...
    -It just died, but it is under warranty. I expect this just happens to be a bad unit, many other people have had theirs for much longer without issue.
    The antenna, however, is great. I can almost bend it in half, and there's no need to get a spring like the firestik guys. Tunable tip, very thin. The only problem I had was a branch that cut off some of the rubber coating, which I repaired with heat shrink easily.
    Years experience:
    This is my first. Did a lot of looking and went to a pro CB shop for help with the install.
    What would I do different:
    If I can't get my Midland repaired, I am considering a Uniden 520 or the Cobra 19. I would like to fit it in the dashboard similar to this. The NOAA I don't think I'd miss, I've never used it. I like dual watch and scan, not sure if those units have it, but I could live without it.
    More info on my build here
    This is where my antenna mount is for quick disconnecting the midland. It's the coin pouch on the right knee.
  16. Jul 22, 2011 at 6:07 PM
    #56
    gryllswannabe
    Larry
    NC
    None yet
    Awesome writeup!! I appreciate all the time you spent setting up this post...
    m3bassman, have you had that cb tuned? Don't get me wrong, I know just about nothing about this stuff, but from everything being said in this thread tuning is the ticket.
  17. Jul 22, 2011 at 7:10 PM
    #57
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Yes i can tell you that as well. Make sure you get a tunable antenna. Firestick FS is the best. Get the on ebay fairly cheap. Dont know much about the wilson antenna if its tunable or not. But yeah that last setup looked nice. Great write up.:D:)
    #57
  18. Jul 23, 2011 at 12:28 AM
    #58
    DIRT YOTA
    Cory
    Camarillo, CA
    Run a separate ground wire from antenna mount down to frame. It will help.
  19. Jul 23, 2011 at 12:49 AM
    #59
    DIRT YOTA
    Cory
    Camarillo, CA
    That lil hole on the mount is for the ground. I bet you will have even better results by grounding it. Another member had it hooked up like that but no ground, he heard fine but transmitted all muffled. Grounded it and all is well. Did u sand the paint off to help ground the mount?
  20. Jul 23, 2011 at 4:24 AM
    #60
    gryllswannabe
    Larry
    NC
    None yet
    I am super reluctant to buy anything right now because I just found out that I can't take my truck to Okinawa, Japan with me. Pretty pissed off about it actually. I guess that it just gives me a little extra time to find exactly what I want. I really like the Cobra 75, and I really like the 19, and the Uniden 520...there are just so many options!!!!
