Cb question
Discussion in 'Audio & Video' started by HolyReptar, Mar 24, 2012.
  1. Mar 24, 2012 at 5:16 PM
    HolyReptar
    HolyReptar [OP] Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    So I just tuned my antenna...
    Channel 1 swr = 1.7, channel 40 swr = 1.7.
    Is that okay? Is there anything I can do to improve that? 3" fire stick ngp
    Behind the cab on the drivers side.
  2. Mar 24, 2012 at 5:21 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    1.7 isnt too bad.
    on mine, i (accidentally) cut about 1/4 inch off of the coax and was able to tune mine down to 1.5. ehh.. it all performs about the same anyway :)
  3. Mar 24, 2012 at 5:22 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    That's acceptable even though not ideal. What's your SWR on Channel 20? I might suggest going with a 4' antenna to get more of it above the roofline if you have the overhead clearance for it (no garage) or using a removable mount if you don't.
  4. Mar 24, 2012 at 5:31 PM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    I didn't check ch 20 so I'll have to check it later
  5. Mar 24, 2012 at 5:37 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    For a NGP that's not bad. You'll be fine. 3 and above is
    when you need to worry.
