CB Question
Discussion in 'Audio & Video' started by ColtsTRD, Feb 3, 2010.
  1. Feb 3, 2010 at 12:58 AM
    ColtsTRD
    ColtsTRD [OP] .....
    Scott
    AZ
    2005 TRD DCSB
    So I have this CB ^ ^ ^ a PA speaker and 4' antenna but no coax cable. I'm wanting to buy some coax cable offline but not sure what to get. Is it all pretty much a universal size or does each CB have its own specific size wire and connector? I tried google but came up empty handed. Thanks for any input :D
    Here's the antenna...
  2. Feb 3, 2010 at 1:36 AM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    CB coax is CB coax. It'll all be the same size, just make sure you get the right connectors for the CB and the antenna. It'd be a good idea to take the CB and antenna into the shop with you. :thumbsup: Good luck!
    I have the same CB. It works great
  3. Feb 3, 2010 at 11:16 AM
    ColtsTRD
    ColtsTRD [OP] .....
    Scott
    AZ
    2005 TRD DCSB
  4. Feb 3, 2010 at 11:22 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I hate to say it, but......Radio Shack should have pre fabbed cable there. Any 50 ohm coaxial cable would work. I made my own out of RG-58. Check out radioshack.
    EDIT: If going with dual antennas (pointles IMO) you want 75 ohm.
  5. Feb 3, 2010 at 11:25 AM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Make sure you get enough too. I needed 17.5ft of my 18ft coax.
  6. Feb 3, 2010 at 11:41 AM
    ColtsTRD
    ColtsTRD [OP] .....
    Scott
    AZ
    2005 TRD DCSB
    Gotcha...I just ordered the coax...I got 18 ft :D
  7. Feb 3, 2010 at 11:46 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Radio Shack Coax Is pure garbage.
  8. Feb 3, 2010 at 12:05 PM
    tacomajim5
    tacomajim5 Well-Known Member
    Jim
    Jacksonville, Florida
    2005 Toyota Tacoma Regular Cab 4x4
    2.5" lift. Bilstein shocks all the way around, Falken Rocky mountain ats2 265/70/17, BHLM, thrush welded muffler, bed liner undercarriage, fender flares and rocker panels, nfab light bar, led off-road lights, grillcraft grill with old Toyota emblem, secondary air filter removed, cb radio, extra hooks in bed, removed front mud flaps, painted pinch weld black.
    "CB coax is CB coax. It'll all be the same size, just make sure you get the right connectors for the CB and the antenna. It'd be a good idea to take the CB and antenna into the shop with you. :thumbsup: Good luck!"
    I hate to sound like a smart ass but all cb coax is not the same. There are different size cb coax depending on how much power you run through your setup. Rg58 is what most people use on regular cb's running 4 watts of power. Rg8 is the thicker kind if you are running more than that. I didn't mean for this to come off like I'm trying to prove you wrong I just figured I would say it in case anyone was wondering.
  9. Feb 3, 2010 at 12:08 PM
    Afwrestler1986
    Johnstown, NY
    No disagreement there. I do radio for a living. But if he wanted it then and there without wait, then that would be an option.
    Absolutely, RG8 is a bit overkill unless you plan on using a foot warmer.
  10. Feb 3, 2010 at 12:53 PM
    PreRunnerSeth
    Apex, NC
    RG-8X would be a good option.
    I personally run LMR200 in my mobile installs.
