cb radio antenna setup help
Discussion in 'Audio & Video' started by 1998purplepickup, May 30, 2018.
  1. May 30, 2018 at 4:48 PM
    1998purplepickup
    1998purplepickup [OP] Well-Known Member
    St. Michaels, MD
    1998 4wd 2.7L Tacoma
    warn vr 8-s winch welded rack and canopy LED bars front and rear Front and rear diff breather ext. lift
    https://www.amazon.com/Firestik-K-4...rd_wg=kwP8S&psc=1&refRID=AXK1RA5C3RG57TXN3PGP
    I have the antenna and part with the coaxial terminal.
    I've been trying to track down the right cable that goes into this coax terminal and since i don't know what it's called, i'm not having any luck.
    it's so simple i'm hoping someone can point me in the right direction. I've called a bunch of places but there aren't to many walk-in stores that stock this type of product where i am.
    thank!
  2. May 30, 2018 at 4:51 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    It's just called coax cable
  3. May 30, 2018 at 4:53 PM
    1998purplepickup
    St. Michaels, MD
    since there are a multitude of terminal variations for coaxial cable, i'm having trouble tracking down the right match for this terminal.
  4. May 30, 2018 at 4:54 PM
    TireFire
    Olympic Peninsula
    Search for the kits and only buy the cable
    1998purplepickup[OP] likes this.
  5. May 30, 2018 at 4:55 PM
    schecter517
    schecter517 MX4LYFE
    Richard
    San Diego
    2014 DCSB TRD Sport 4x4
    TRD Pro Wheels Falken WildPeak AT3W 265/70-17 Black Spyder Projector HL w/LED Bar Morimoto XB LED Fog Lights Spec-D Black Tail Lights Truxedo Deuce 2 Tonneau Cover Tinted Windows Bed Mat Debadged Blue LED Interior Lights LED Switchback Turn Signals Led Reverse Lights and License Plate Lights DDM Ultra HID 55W 55K Kit
    PL-259 connector. try searching that
  6. May 30, 2018 at 4:55 PM
    TireFire
    Olympic Peninsula
    I have the same stud on my truck sorry I can't remember details cuz it's been so long
  7. May 30, 2018 at 4:56 PM
    1998purplepickup
    St. Michaels, MD
  8. May 30, 2018 at 7:08 PM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    Not if this will help but here goes
    Mobile[​IMG]Logo
    HomeLearning Center ⟩ Complete Guide to CB Coax
    COMPLETE GUIDE TO CB COAX
    It may not seem very sexy, but coax is important stuff. Select cheap coax, and you may save a few bucks today. But you'll be kicking yourself in 6 months when your coax fails right before a weekend trail ride or at the beginning of an important work day.
    DIFFERENT TYPES OF COAX CONNECTIONS
    PL-259 CONNECTIONS (BARREL STYLE)
    The PL-259 coax connection is the most popular in the CB world. It has a barrel / screw-on type look, as can be seen in the picture below.
    All CB coax will have a PL-259 connection on at least one end, as this is the standard type of connection that plugs into the back of all CB radios. Depending on the coax purchased, the other end of the coax could be another PL-259 style end - or alternatively a ring-style or even lug-style connection.
    RING STYLE CONNECTIONS
    Ring-style coax ends are another popular way to connect the CB coax to the mount. Compared to PL-259 connections, they have two significant advantages.
    First, they have a lower profile and allow the coax to come off the mount at a 90 degree angle vs straight down. This is advantageous for tight mounting situations.
    Secondly, because they're made exclusively of plastic they tend to hold up to the weather and moisture better than the metal made PL-259 connection. The chances of them becoming rusted or stuck are significantly less.
    LUG / TERMINAL STYLE CONNECTION
    While it's not as popular as a PL-259 or ring-style coax, the terminal style connection is used in a few unique circumstances. Terminal style coax connects using a small o-connection, and is often used when a very clean and sleek mounting application is required - like for a side or ball mount that utilizes both the inside and outside of a mounting surface.
    FME SCREW-OFF ENDS
    When routing coax cable, you'll often be working with small firewall opening or holes. In these cases, it's really a pain to have a large, PL-259 connector that's too big to fit through the smaller opening. It forces you to either remove the PL-259 connection and re-solder it on once routed OR drill a larger hole.
    FME connections are great because they allow you to remove the PL-259 connection (see picture below) for easy routing of the smaller diameter coax. Then, once the cable is successfully routed, you can simply screw the cable back together using the FME connection (instead of messy soldering) and you're ready to go.
    It's the best of both worlds: large PL-259 or ring-style connections with the convenience of tiny cable routing.
    DIFFERENT QUALITY GRADES OF CB COAX
    RG-58 (STANDARD COAX)
    This is the standard grade coax included with many kits, mounts and packages. It has average shielding and an average thickness exterior with the cable diameter measuring about 0.20".
    For RG-58 we'd recommend Firestik's coax - either this ring-style coax with FME connector (very popular) or their standard dual PL-259 CB coax.
    RG-8X (PREMIUM COAX)
    RG-8X is like standard coax on steroids. It has a stranded center, which makes it less likely than a solid center (found on cheaper coax) to snap when bent and pinched. It usually also has beefier insulation, and is just thicker in general measuring in at around a 1/4" diameter.
    If you'll be using your coax in heavy-duty conditions and want something that's more likely to hold up to abuse, we recommend going with RG-8X coax.
    For a great heavy-duty choice, consider this 18' PL-259 RG8X CB coax cable.
    RG-59 (DUAL ANTENNA COAX)
    If you're running dual antennas, you must use RG-59 coax. Any other type of coax won't work with your dual antenna setup.
    Some people will purchase regular coax cable and try to use a T-connector to install everything. While everything will wire up, your dual antenna system simply won't work properly. You can see all of our RG-59 style CB coax here.
    OTHER QUALITY FACTORS
    STRANDED CENTERS
    Most cheaper coax utilizes a solid center carrier wire. Because it's just one piece, if it breaks or splinters, your coax is worthless and can no longer carrier a signal. One door slam and your coax could be toast.
    With a stranded center made up of many smaller carrier wires, you're much less likely to lose your signal. Even if one of those strands break, you have numerous backups that will ensure your signal gets through.
    All RG8X coax will have a stranded core. To know if RG-58 or RG-59 does, check the product description or see if it includes a "A/U" designation, which indicates a solid core.
    HAND SOLDERED VS. MACHINE SOLDERED
    You may also hear the term "hand soldered" ends when reading about coax. This simply means that the PL-259 ends were soldered on by human hands, and not by a machine. This usually indicates that the connection and work will be of superior quality, and less likely to be faulty and/or break in the future.
    OUR TOP COAX RECOMMENDATIONS
    18' OF RG-8X PREMIUM COAX
    One of our top recommendations is 18' of extremely durable, high-quality RG8X CB coax. If you'll be abusing your coax or just really want it to hold up well, this is the coax for you.
    18' FIRESTIK RING STYLE W/ FME CONNECTOR
    This super convenient ring-style CB coax end and FME make installation simple. While not full RG8X, it does have a stranded center for enhanced durability. The ring-style coax connection is weather resistant and won't rust, while the FME connection makes it easy to route the coax through small holes in the tub and/or firewall.
    SEE ALL OUR COAX BY TYPE
    RAGS2WRENCHES and stbear like this.
