CB Radio Information and Installation
Discussion in 'Audio & Video' started by Frogsauce, Jun 2, 2013.
  1. Dec 4, 2013 at 9:28 AM
    #221
    skygear
    skygear                    
    Yeah, glad your back. Hope all is well.
  2. Dec 5, 2013 at 4:16 PM
    #222
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    You are correct, I stated it like that as it is sideband capable also.
  3. Dec 7, 2013 at 5:10 AM
    #223
    CircuitBreaker
    CircuitBreaker Well-Known Member
    Stephen
    Colorado Springs, CO
    13 Tacoma TRD
    But sideband isn't another band, it's simply a mode.
  4. Dec 8, 2013 at 5:06 AM
    #224
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    That is correct same frequency different mode. The biggest problem is finding some one else that also has SSB most CB radios do not. I still have a Tram Diamond SSB radio I bought in the early 70's have not used it in 30 years.
  5. Dec 22, 2013 at 6:10 PM
    #225
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    Here's a question for anyone who knows whats up: I just mounted my firestik on a home made mount that is very similar to the relentless hood mount, apparently I made a bend just a little too far so now the firestik is angled to the back of my truck about 10 or so degrees. Does the antenna need to be perfectly vertical or am I good to go? I plan on tuning it tomorrow and i'd like to have the antenna set up right for this.
  6. Dec 22, 2013 at 6:14 PM
    #226
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    Sub'd. Probably my next mod...
  7. Dec 22, 2013 at 6:23 PM
    #227
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    You and I both. I just ordered the Uniden 880
    -edit-
    Scratch that. Too indecisive. :(
  8. Dec 22, 2013 at 7:10 PM
    #228
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    I want something small so it fits in my counsel and I can still use it as a counsel. Haven't decided which one yet but I will in the next week or so. I kinda like Dennis'.
  9. Dec 22, 2013 at 7:14 PM
    #229
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    Check out Uniden 520xl pro.
  10. Dec 22, 2013 at 7:18 PM
    #230
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    That's perfect! Thanks. :D
  11. Dec 31, 2013 at 9:43 AM
    #231
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    Hey guys I am really confused when it comes to this CB stuff. I have my coax cable (with connectors at both ends) Firestik antenna and a spring mount. The radio (Uniden 520xl) is on the way. I am extremely confused on how the heck you attach the cable to the antenna.... School me please.
  12. Dec 31, 2013 at 12:39 PM
    #232
    12thmanhawkfan
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
  13. Dec 31, 2013 at 12:50 PM
    #233
    TRDtexasTaco
    TRDtexasTaco Well-Known Member
    JP
    Sunnyvale Trailer Park
    06 TRD PreRunner
    Billy shocks, Maxtrac spindels, AllPro standard leafs, BAMF shock relocation, King 2.5 smoothies
    sub'd great write up
  14. Jan 1, 2014 at 6:39 AM
    #234
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Do you have a stud mount? Coax and your antenna screw into that.
  15. Jan 1, 2014 at 7:06 AM
    #235
    TacoBurrito07
    Jake
    Arizona
    I don't. I just have a spring mount. How am I supposed to use it with the antenna?
  16. Jan 1, 2014 at 8:03 AM
    #236
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    You need a stud. Should look like this when you're done.
  17. Jan 1, 2014 at 9:14 AM
    #237
    TacoBurrito07
    Jake
    Arizona
    Okay. So when I have the stud, the coax plugs Into the bottom, and the antenna screws in the top. Can I screw it into the spring mount and then the spring mount into the stud mount?
  18. Jan 1, 2014 at 9:15 AM
    #238
    rbraddock
    rbraddock Well-Known Member
    Randy
    Hampton, VA
    13 DCSB
    6" ProComp lift from the dealer, slow build in progress
    Yes
  19. Jan 1, 2014 at 9:16 AM
    #239
    TacoBurrito07
    Jake
    Arizona
    Alright thanks.
  20. Jan 2, 2014 at 5:26 AM
    #240
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you decide to use a spring tune the antenna after you put the spring on.
