CB Radio Information and Installation
Discussion in 'Audio & Video' started by Frogsauce, Jun 2, 2013.
  1. Jan 24, 2014 at 1:21 PM
    #261
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    Awesome thanks fellas! thinking I may have to snag it then!
  2. Jan 25, 2014 at 6:37 AM
    #262
    CircuitBreaker
    CircuitBreaker Well-Known Member
    Stephen
    Colorado Springs, CO
    13 Tacoma TRD
  3. Feb 1, 2014 at 6:20 PM
    #263
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    why is this not a sticky?
    This thread deserves to be a sticky.
    Great information from the beginner to the expert.
  4. Mar 23, 2014 at 9:20 AM
    #264
    NCTacoma
    NCTacoma Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    I know that you can power the CB off a fuse or a home run to the battery. If you do the home run, can you add an inline switch to kill the CB? The only reason I suggest this is if the CB is in an out of the way location in your truck?
  5. Mar 23, 2014 at 9:25 AM
    #265
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    You can add an inline kill switch to anything....
  6. Mar 23, 2014 at 4:29 PM
    #266
    Frogsauce
    Frogsauce [OP] Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    That is how I installed it in this thread. I got a CB switch from here: http://www.otrattw.com/proddetail.php?prod=VVPZCCB-500 instead of using the blue one you see in the pictures.
  7. Mar 23, 2014 at 7:01 PM
    #267
    NCTacoma
    Caleb
    CLT, NC
    This is what I was thinking.
    I kind of skimmed your article, didn't have time to read it all. Seems like a good write up though. Thanks for the input.
  8. Mar 30, 2014 at 7:19 PM
    #268
    skygear
    skygear                    
  9. Mar 30, 2014 at 7:29 PM
    #269
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    If you add a spring you will have to retune your antenna.
  10. Mar 30, 2014 at 8:51 PM
    #270
    skygear
    skygear                    
    Do you recommend a spring with a hood mount? or in general? or is it a waste?
  11. Mar 31, 2014 at 4:02 AM
    #271
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    It's OK, but you might want a cushion to go around the antenna. Putting it on at a point where if it were to hit your hood/window, the cushion would hit instead of the antenna. I have seen some Jeep guys use a rubber bushing from a shock.
  12. Mar 31, 2014 at 4:33 AM
    #272
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    A stiff antenna like a fire stick may well damage what ever it is attached to or break the antenna if it has no give.
  13. Mar 31, 2014 at 6:35 AM
    #273
    skygear
    skygear                    
    ordered a medium stainless steel spring. Not going to use the hood mount, *yet. My ARB Bull Bar has the 2 aerial mounts. Going to see how it fairs there.
    This was not something I researched at all before getting it. There was an opportunity to help someone out and benefit from it in trade.
    Lots of research going on now.
    What is a "whistle"?
    I was watching a youtube video of a review. Guy kept saying 'if you wanted to hook up a whistle to it' -> I assume it is an AMP?
  14. Mar 31, 2014 at 11:15 AM
    #274
    CircuitBreaker
    Stephen
    13 Tacoma TRD
    Honestly, you really shouldn't need a spring with just a 3' Firestick mounted where it is. It won't hurt but would probably be okay without it.
  15. Mar 31, 2014 at 12:47 PM
    #275
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I have a spring on mine in the front corner of the bed. The antenna hits branches/parking decks/drive through bars a lot.
  16. Mar 31, 2014 at 2:22 PM
    #276
    skygear
    skygear                    
    So does anyone know what this term 'Whistle' means?
  17. Mar 31, 2014 at 4:22 PM
    #277
    Sandman614
    Tim
    '06 SR5 Off Road
  18. Mar 31, 2014 at 4:58 PM
    #278
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    That's what I would guess. Key up sounds. Which are very annoying by the way.
  19. Apr 1, 2014 at 10:27 AM
    #279
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    No worse than a "Roger beep".
  20. Apr 2, 2014 at 5:47 PM
    #280
    Sandman614
    Tim
    '06 SR5 Off Road
    Help. The outer shell of my firestick cracked open today. Should I cut the rest off and get some heatshrink that's large enough?
