CB Radio Information and Installation
Discussion in 'Audio & Video' started by Frogsauce, Jun 2, 2013.
  1. May 20, 2014 at 8:54 AM
    #321
    Hunter.V.White
    Hunter.V.White Well-Known Member
    Hunter
    Fairbanks, AK
    2013 DC 4WD TRD-Off Road
    Pelfreybilt Steel Armor, Famous Fabrication Sliders, OME 3" Lift, 886x coils, Dakar Leaf Packs, TC UCA's, Fuel D551 Wheels, 285/70/R17 Toyo Tech RTs, Warn Zeon 10s Winch, Rigid Industries 20" E2 Flood, RI 20" SR Spot/flood, RI Duallys, SwitchPro SP8100, Uniden Bearcat 680 CB Radio.
    Great write up. Thanks for taking the time to pass on the knowledge.
    Hunter
  2. Jun 12, 2014 at 1:02 PM
    #322
    08PreTac
    08PreTac Mr sneed
    Brandon
    Charlotte NC
    08 prerunner dc sb
    extant solid fold, plasti dipped grille, lime green emblem, lime green badges, deflapped
    the more i read the more my head hurts......i have a 10ft whip antenna i want to mount to the front ( near the cab) of my bed....from what i am reading...this can not be done?
  3. Jun 12, 2014 at 3:45 PM
    #323
    Frogsauce
    Frogsauce [OP] Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    Sure it can, what are you having trouble with? Maybe we can help out.
  4. Jun 12, 2014 at 3:48 PM
    #324
    08PreTac
    08PreTac Mr sneed
    Brandon
    Charlotte NC
    08 prerunner dc sb
    From what I am reading...The mount has to be grounded....The beds of the newer tacos are a composite...so no metal to ground to on the inside
  5. Jun 13, 2014 at 11:43 PM
    #325
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    This is correct. You can purchase mounts with grounding provision built in. And run a ground wire to the nearest point on your chassis. Not only do we need to do this on our beds, but also upfront, for hood-mounts. (The hood hinge is a bad ground connection).
  6. Jun 14, 2014 at 6:19 AM
    #326
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    electrical ground =/= ground plane...
  7. Jun 14, 2014 at 8:37 AM
    #327
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    With a 10 foot whip I'm sure you'll be fine. There will be enough antenna over the roof for a decent ground plane. The problem people generally have when mounting an antenna in the bed is having an antenna that is too short. The bed rails from what I have heard are grounded by the way but it wouldn't hurt to ground the mount to the frame if you have SWR issues. Good luck!
  8. Jul 27, 2014 at 12:53 PM
    #328
    tylershane17
    tylershane17 Back to Back World War Champions
    Tyler
    Northwest Alabama
    2007 TRD OFF ROAD DCSB
    Brushguard, Lift.
    If you use the lil Wil and run it through the 3rd brake light where do you drill your hole for the coax connector?
  9. Jul 27, 2014 at 1:26 PM
    #329
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
  10. Jul 27, 2014 at 2:43 PM
    #330
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    If you're talking about a mag mount, I did something similar on my Runner. I ran the coax thru the rubber grommet and sealed it back up with black rtv; should be some pics in my build thread.
  11. Jul 27, 2014 at 3:10 PM
    #331
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
    Thanks man I'll check it out
  12. Aug 15, 2014 at 2:44 PM
    #332
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
    I read some words of inspiration a while back. The words were "wilson 1000 that shit" can't remember who by but I did exactly that and have never been happier. Had a flat swr across all channels and didn't even have to adjust it.
  13. Aug 16, 2014 at 5:26 AM
    #333
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Good choice. Love my Wilson 1000.
  14. Dec 6, 2014 at 11:05 AM
    #334
    usptwins
    usptwins Well-Known Member
    Trey
    Louisiana
    Taco SR5 Stock stock stock
    Kyb shocks/struts, Nitto Terra Grappler G2's in 285/70R17.
  15. Dec 6, 2014 at 11:28 AM
    #335
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Subbing for when I fix my cb
  16. Dec 7, 2014 at 6:53 PM
    #336
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Fast question on antennas:
    Are the bed rails grounded? With the composite bed I'm not sure and I don't have a multimeter. So, if I install a steel bracket to the inner steel bedrail, and install my antenna to that, will the antenna be grounded, or will I need to run a ground strap to frame?
    I realize a few posts above hint at rails not being grounded but then there is a post indicating that they are.
  17. Dec 8, 2014 at 5:06 AM
    #337
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The rails are bolted to the body not the plastic other wise they would not be on there very long. Take one of the screws out you'll find that they are machine thread don't forget the hold downs are rated 200# each no real chance of the rail staying on screwed into plastic. .
  18. Dec 8, 2014 at 5:11 AM
    #338
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    That's called a nut-sert. They are installed into the fiber-composite bed. You still need to ground the antenna. Double check it with a multimeter.
  19. Dec 8, 2014 at 5:58 AM
    #339
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well there are two types of grounds, a DC ground and an RF ground involved with radios and both are part of a good mobile install. There is literally days’ worth of reading on this subject try a search “dc vers. rf grounds”.
  20. Dec 8, 2014 at 10:25 AM
    #340
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Thanks, that's about what I expected.
