CB Radio Information and Installation
Discussion in 'Audio & Video' started by Frogsauce, Jun 2, 2013.
  1. Jun 5, 2013 at 6:39 AM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    Excellent write up! I subbed this for future reference.
  2. Jun 5, 2013 at 6:43 AM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Nice write up! I started having flashbacks to training I had at work when I read "radio signal propagation".
  3. Jun 5, 2013 at 6:44 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Ok now I am confused. So what is the better cable for the antenna
  4. Jun 5, 2013 at 7:01 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Not a bad write up, although there are a few holes in it.
    Questions about Coax: Best by far 400max http://www.dxengineering.com/parts/dxe-400max
    Space concern and a good performer: rg8x http://www.dxengineering.com/parts/dxe-8x
    I use 400 max for HF and CB, while VHF and UHF rg8x, I also only run 7 feet(HF/CB) of with no SWR issues ( I am not using off the self antennas)
    Firestick did that write up because of inefficiencies in there antennas and attempting to catch a null in the wave in order to gain favorable SWR.
    Likewise Coax selection for mobile use and noise is very difficult to say will make a difference as you are not Earth ground nor are most CB's on the market filtered to compensate for Vehicle devices.
  5. Jun 5, 2013 at 7:07 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Mini-8 is fine for most mobile set-ups as long as there is no extra power involved. Once you add power it is inferior and must be upgraded. The problem with mini-8 is it really isn't regulated so there is some really low quality stuff out there. Don't skimp on the antenna and the coax and you will be fine.
  6. Jun 5, 2013 at 7:09 AM
    BostonBilly
    Easton
  7. Jun 5, 2013 at 7:41 AM
    Frogsauce
    Frogsauce [OP] Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    ^ He's got it.
    I had actually used RG8X for the antenna and power.
    RG8X is not much more expensive and is good quality. For a usual CB application, RG8X is fine. I updated that section in the write-up.
  8. Jun 5, 2013 at 7:46 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    I grounded it to a screw below the tail light. It's hard to see the bolt I used in the picture (Section 7), but it's the red wire coming out of the tail light and anchored to the bolt on the left side of the picture.
    Where ever you decide, make sure it is grounded to the frame for the best ground.
  9. Jun 5, 2013 at 7:56 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    RG8X is Mini-8. RG8U is a better coax. There are a shit ton of different types just depends on how involved you want to get and how well you want your set-up to perform.
    This calculator has a ton of good info on coax....
    http://www.timesmicrowave.com/cgi-bin/calculate.pl
  10. Jun 5, 2013 at 8:22 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Oh, I didn't realize they were one in the same. Thanks!
  11. Jun 5, 2013 at 9:48 AM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    Thanks Chris, i'm going to ground to the frame,i just wasn't sure where the antenna itself was grounded.
    This is the mount i made.
  12. Jun 5, 2013 at 9:51 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    sorry for the noob question but i have a 3 ft tuneable firestik II and i have no clue how to ground the antenna??? how do you just ground the antenna and not the mount? it will be mounted on one of relentless fabs hood cb mounts.
  13. Jun 5, 2013 at 10:07 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Very nice.
    What kind of antenna do you have? It may not be grounded the same as mine. I used a Wilson 4' flex.
  14. Jun 5, 2013 at 11:24 AM
    64Wildcat
    Denis
    New Hampshire
    2015 Rubicon
    3' Firestik
  15. Jun 5, 2013 at 11:50 AM
    #35
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    You guys may have the No Ground Plane (NGP) antennas. These do not require grounding. Try looking up your exact model and see if it says No Ground Plane or NGP. I think the Firestik II is not a NGP though.
    If it's not an NGP antenna, then you will need to make sure the mount itself is grounded. You can run a wire from the mount to a location on your truck that connects to the frame (or directly to the frame). Just make sure whatever you attach to, it's not painted. You can use a continuity tester to determine if your grounded or not. Or look at your SWR reading, it will be way over 2.
    Something like this:
  16. Jun 5, 2013 at 11:56 AM
    #36
    TacoFMS
    Justin
    Louisa County, VA
    so if i just put the mount from relentless on wouldnt the mount already be grounded? i mean since it uses the bolts that hold your hood on to mount it? or am i wrong?
  17. Jun 5, 2013 at 12:15 PM
    #37
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I have a 3' NGP Firestik mounted in the front drivers corner of my bed. I am getting High SWR, any suggestions?
  18. Jun 5, 2013 at 12:24 PM
    #38
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Yeah, ditch the NGP Firestik. I had one and it was crap, could never get my SWR down low enough.
  19. Jun 5, 2013 at 12:25 PM
    #39
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea, I see the roof mount in your sig. I'm not going there.
    I'm curious if a GP antenna in the same location would be any better.
  20. Jun 5, 2013 at 12:34 PM
    #40
    TacoFMS
    Justin
    Louisa County, VA
    ok so i looked up the part number on my antenna and it is a firestik II with a part number of FS3-b.... so im guessing its not an NGP antenna then???
