CB Radio Information and Installation
Discussion in 'Audio & Video' started by Frogsauce, Jun 2, 2013.
  1. Oct 14, 2015 at 3:44 PM
    #381
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    Yes, it needs to be sealed. I've had sucess with clear silicone but other waterproof products will also work.
  2. Oct 15, 2015 at 4:17 AM
    #382
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    You can unwrap/cut the electrical tape at that grommet and use some needle nose pliers to spread the grommet so you can push/pull the coax cable through. Then you can just wrap it with some new electrical tape rather than worrying about having to seal a new hole.
  3. Oct 16, 2015 at 7:25 AM
    #383
    CircuitBreaker
    CircuitBreaker Well-Known Member
    Stephen
    Colorado Springs, CO
    13 Tacoma TRD
    I've never had an issue. I just make the hole a bit smaller than the diameter of the coax. The tight fit of the rubber grommet on the vinyl of the coax kind of self seals itself.
  4. Sep 17, 2016 at 12:46 PM
    #384
    vinnyp
    vinnyp Well-Known Member
    Summit County, Colorado
    2015 Silver Sky TRD Sport
    3" Lift, 18" Fuel Lethal Wheels, 33" BFG KO2s
  5. Jan 18, 2017 at 9:23 PM
    #385
    ovrlandfam
    ovrlandfam Well-Known Member
    10' dbl cab TRD sport
    Trail gear tube rear bumper, Westin brush guard,
    Need a little help guys. I have my firestick II mounted to the stock bed rail just behind the drivers side rear window. Mount is steel angle iron. I have a 2' found cable from the male end of the antenna screw/mount and other end goes to my chassis. I have high SWR. did a test and held the antenna in my hand off the mount and just slipped the ground between the flexible spring mount and was able to get good low SWR readings. What gives??
  6. Jan 19, 2017 at 6:16 AM
    #386
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Drainbung, fatfurious2 and Shikokaon like this.
  7. Jan 19, 2017 at 6:21 AM
    #387
    Shikokaon
    Shikokaon Slacker Extraordinaire
    Portland, OR
    2017 Tacoma D-Cab Off Road (MT)
    Is there any "coating" on the screw/mount were you attached the ground onto? Maybe its not making "good" contact?
  8. Jan 19, 2017 at 6:22 AM
    #388
    Shikokaon
    Portland, OR
    Thank you! This should come in handy!
    Sandman614[QUOTED] likes this.
  9. Jan 20, 2017 at 10:05 AM
    #389
    ovrlandfam
    No coating at the ground. Does it matter if the mounting hole is just big enough to fit the stud mount? If the stud mount touches the inside of the hole is that ok? My stud is mounted like the pic above, left diagram. Lock washer, flat washer, nylon washer, mount, ground, stud then coaxial cable. From top to bottom.
  10. Jan 20, 2017 at 11:40 AM
    #390
    Shikokaon
    Portland, OR
    As far as i know the stud part that attaches to antenna should NOT touch any part of the mount (hence the nylon washers with a small "lip" on them so it stays centered. For the LEFT picture the "outside" of the connector CAN touch the mount, as that is what would give the ground for the coax cable.
  11. Jan 21, 2017 at 8:04 PM
    #391
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    I resently bought a SWR meter and my readings are high. I checked my antenna for proper ground and even redid the ground wire from the mount to the frame. I don't have continuity between the hot and ground surfaces. I'm running a cobra 75, 18' coax, heavy duty spring and firestick WK4. Any help would to apprecited. Thanks
  12. Jan 21, 2017 at 8:08 PM
    #392
    Sandman614
    Tim
    '06 SR5 Off Road
    HOT cannot touch GROUND
    Correct, the HOT side of the antenna needs to be insulated from the mount which is GROUND. You are essentially shorting out the circuit.
  13. Jan 21, 2017 at 8:20 PM
    #393
    Sandman614
    Tim
    '06 SR5 Off Road
    More than likely you need to adjust your antenna. Some firestik have an adjuster bolt under the cap on the tip. If yours doesn't you can remove the spring and check again.
    How to adjust/tune your antenna:
    https://www.rightchannelradios.com/blogs/installation-guides/18330687-cb-antenna-tuning-instructions
  14. Jan 21, 2017 at 8:30 PM
    #394
    POOLGUY
    JEFF
    ALABAMA
  15. Jan 21, 2017 at 8:35 PM
    #395
    Sandman614
    Tim
    '06 SR5 Off Road
    Depends on how squimish you are to cut your antenna. Like I said, take off the spring and see how your numbers change. If they get better or worse then you need to tune your antenna by lengthening(not really possible, so don't cut too much) or shortening your antenna. If your number stay the same it could mean something else is wrong.
  16. Jan 21, 2017 at 8:35 PM
    #396
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
  17. Jan 21, 2017 at 8:42 PM
    #397
    Sandman614
    Tim
    '06 SR5 Off Road
    Just to add more pics and videos on the following topics:
    Connecting CB antenna/Ground
    reposting
    Tuning a cb
    https://youtu.be/GiMVAuOefXo
  18. Jan 23, 2017 at 11:23 AM
    #398
    ovrlandfam
    Ok so I made the hole on the mount larger and that fixed the problem. On the meter I was able to 1.0 on ch 1, 1.2 on ch 20 and 2.0 on ch 40. Best I could get. I'm happy with it. Thanks for the help.
    Sandman614 likes this.
  19. Jan 23, 2017 at 12:00 PM
    #399
    Sandman614
    Tim
    '06 SR5 Off Road
    Sounds good, glad it was an easy fix.
  20. Jan 30, 2017 at 10:22 PM
    #400
    Sk323i
    Sk323i Well-Known Member
    can you recommend a good radio install for a 2017 Tacoma OR Premium?
    I want to be able to pick up local area police, fire, EMT, radio.
    I live near an airbase - so military channels are probably all over the place. It would be nice to hear whats going on - on base channels too.
