CB Radio Information and Installation
Discussion in 'Audio & Video' started by Frogsauce, Jun 2, 2013.
  1. Jan 31, 2017 at 3:34 AM
    #401
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    @Sandman614, thank you for your post on antenna mounting and tuning. Over the weekend I figured out my problem. The antenna I have just isn't compatible. I hooked up a friends antenna, and it brought my SWR readings down into range. I'm going to get a new antenna and check it again.
  2. Jan 31, 2017 at 4:28 AM
    #402
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    You cannot tap into military frequencies b/c we are on different waves than civilians. Plus we don't use CBs or HAM.
    Sk323i[QUOTED] likes this.
  3. Jan 31, 2017 at 4:30 AM
    #403
    mrbedgood
    North Carolina
    What length and type do you need? I have a 4' firefly firestik laying around now. I meant to order a 3', which is on the way now. So I have a 4' laying around. Brand new still in box.
  4. Jan 31, 2017 at 5:29 AM
    #404
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Interesting. What antenna do you have and what antenna did does your friend have?
  5. Jan 31, 2017 at 10:28 AM
    #405
    POOLGUY
    JEFF
    ALABAMA
    Mine is a kw4 firestik 4'. He has a tunable 5' firestik. I have to check my receipt but, I believe I can upgrade the one I have.
  6. Jan 31, 2017 at 3:43 PM
    #406
    Sk323i
    Sk323i Well-Known Member
    any threads you recommend for a car radio noob like me?
    I want to join the air force eventually - hopefully I will learn more about communications.
  7. Jan 31, 2017 at 6:16 PM
    #407
    mrbedgood
    North Carolina
    Nae man I can't. I'm just getting into CBs myself. I just know a little about military radios and freqs to get me by and through shit.
  8. Jan 31, 2017 at 8:07 PM
    #408
    POOLGUY
    JEFF
    ALABAMA
    Ok guys, I thought he had a tunable 5' firestik. well as it turns out its just a kw5 firestik (5'). So after doing some research my 4' antenna is 400watts and his 5' antenna is 500watts. I was wondering if I could just get a 4' tunable antenna which is 900watts? If someone can explan to me the differents between the different watts between the antennas, I think that would help me a lot in understanding how it all works.
    BTW: my SWR readings are ch1- 2.8 and ch40- 3.5 with the 4'
    ch1- 1.5 and ch40- 2,1 with the 5'
    Thank you!
  9. Jan 31, 2017 at 8:33 PM
    #409
    Sandman614
    Tim
    '06 SR5 Off Road
    CB only 'legally' outputs 4watts, so the branding of 500watts/900watts is silly. If you really want to really look into something research 1/4wave, 5/8wave, etc. If the antenna is labelled for CB and fits your need of Ground Plane vs No Ground Plane(boat, RV, motorcycle, and other low ground plane installations), then it should be good. The length will help you transmit and receive performance, generally longer == better. You need to Tune your antenna. If it doesn't have a tuneable tip(screw) then you will need to cut it shorter, even if the readings say it's too short you can't add onto it. Too short is relative, antenna "lengths" and repeats themself, so once you take enough off it will be too long for the next "length".
    Pics of where it's installed?
  10. Jan 31, 2017 at 8:35 PM
    #410
    Sandman614
    Tim
    '06 SR5 Off Road
  11. Jan 31, 2017 at 9:08 PM
    #411
    POOLGUY
    JEFF
    ALABAMA
    So it sounds like I should go with the 5' tunable.
    As for the mount; Its mounted on the right back corner by the tail light.(I know left side would be better but, its also my company truck. Left side would be in the way). I have it grounded to the frame. Checked it with my meter, hot is hot and ground is ground. Coax is ran behind the tail light, along the frame, into the cab from under the passanger seat to under the center cup holders. I'll post a picture tomorrow. One thing rhat I'm concerned about is my bed rack is also reading grounded to the truck and antenna ground.
  12. Jan 31, 2017 at 9:27 PM
    #412
    Sk323i
  13. Feb 1, 2017 at 5:56 AM
    #413
    Sandman614
    Tim
    '06 SR5 Off Road
    nah
  14. Feb 1, 2017 at 6:20 AM
    #414
    POOLGUY
    JEFF
    ALABAMA
    Picture of install:
  15. Feb 1, 2017 at 6:21 AM
    #415
    Sandman614
    Tim
    '06 SR5 Off Road
    Everything seems to check out. You just need to Tune your antenna, whatever length you prefer. It's also possible your 4' antenna is damaged.
  16. Feb 1, 2017 at 11:51 AM
    #416
    POOLGUY
    JEFF
    ALABAMA
    What do you do to tune it? Both SWR readings are high. All I found was on if one or the other was high.
    Thank you for all of your help!
  17. Feb 1, 2017 at 2:30 PM
    #417
    Sandman614
    Tim
    '06 SR5 Off Road
    Remove the spring and check again. It's likely the spring is a problem.
    Read this too.
    http://www.wearecb.com/troubleshoot-a-high-swr.html
  18. Feb 1, 2017 at 8:02 PM
    #418
    POOLGUY
    JEFF
    ALABAMA
    Thank you! You have given me some more homework for the weekend. I greatly appreciate all for your help.
  19. Feb 2, 2017 at 4:45 AM
    #419
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
  20. Feb 20, 2017 at 1:56 PM
    #420
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    I'm getting a Galaxy DX-98VHP radio. Getting it tuned from bells cb in florida. With a Wilson 1000 magnatic roof mount. I have a 2017 TRD ORDC W/ premium and technology package. Can I mount the antenna close to the shark find on top of the truck? Or does there need to be some separation?
