CB Radio Information and Installation
Discussion in 'Audio & Video' started by Frogsauce, Jun 2, 2013.
  1. Jun 5, 2013 at 12:43 PM
    #41
    Frogsauce
    Frogsauce [OP] Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    Possibly, but test it to make sure. You don't want to run a radio with high SWR for long. If your mount is grounded, the antenna is probably grounded. But if the mount is painted, it may not be well grounded.
    Yeah NGP antennas are hard to get low SWR readings on. If your using a standard coax instead of NGP specific, you could also be having performance issues from that.
    There are some nice NGP kits out there, but they are usually for boats and come as a complete NGP specific kit. No NGP kit will perform as well as a grounded one.
  2. Jun 5, 2013 at 12:44 PM
    #42
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Correct, that is NOT a NGP antenna. You will need to confirm that the mount is grounded. If it's not, just run a ground wire from it to a ground point on the truck.
  3. Jun 5, 2013 at 12:46 PM
    #43
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Where the hell was this thread 3 weeks ago! lol Mine works great now, but I had to look hard for the right information. Great write up OP!
  4. Jun 5, 2013 at 12:47 PM
    #44
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I have the one I linked, It's the Antenna, bracket, cable kit. I like the location and would rather not change it..
    Here's the 3 sets of readings I took while adjusting it.
    Ch1. 3 / 2.3 / 3
    Ch19. 1.4 / 1.3 / 1.4
    Ch40. 2.7 / 3 / 3
  5. Jun 5, 2013 at 12:47 PM
    #45
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    hmm. ok. thanks, i'll keep that in mind. im probably gonna tape off the area where it mounts to the hood and then put a piece of tape around the antenna hole before i paint it. hopefully that will help me catch a ground.
  6. Jun 5, 2013 at 12:58 PM
    #46
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Troubleshooting an NGP antenna is not my strong point, but I would try to move it around and see it the SWR improves. You could be reflecting back from a surface. Check these links and see if you find something useful:
    http://www.firestik.com/Tech_Docs/ngp-critical.htm
    http://www.firestik.com/Tech_Docs/NGP_Install.htm (check the "Tuning" section)
  7. Jun 5, 2013 at 3:01 PM
    #47
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Nice effort and very good overall, but there's misleading info and several inaccuracies in sections 3 & 7. To get a better understanding of how a CB antenna actually works, and why both a ground and a ground plane (placement of the antenna on a large flat metal surface) are important, I suggest your readers pick up a good CB book (from eBay or wherever) or view some of the ham radio sites describing/discussing vertical dipole antennas in mobile applications - exactly what a CB antenna is.
    In fact, if you keep an eye on eBay, you can even occasionally find older military training manuals discussing radio fundamentals, including mobile vertical dipole antennas similar to a CB antenna.
    The CB books are often written for beginners, so are usually the easiest to read and understand. They're also written directly for CB, while you can only use the general theory from the other sources mentioned, which will have to be converted to CB, since they're discussing other radio services, other frequencies, and similar.
    #47
  8. Jun 5, 2013 at 3:11 PM
    #48
    Manwithoutaplan
    ID
    just get a ham radio.
  9. Jun 5, 2013 at 4:53 PM
    #49
    Deathproofduck
    Deathproofduck Well-Known Member
    13 StormTrooper DCSB Icon, scs, front runner..etc
    Too many to list
    It looks sorta like learning Photoshop. I got some good general knowledge from this thread. If i wanted, i could take up this new hobby, devote all my time, buy some books and study, and blow tons of money...for?...A CB?. Good thread OP, i have the time and money just not the patience to follow through on 90% of what was posted after you.
  10. Jun 5, 2013 at 4:54 PM
    #50
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Right, but this isn't written for a target audience of amateur radio guys. It's for the general CB user who doesn't want to spend a bunch of time looking up all these different threads. This was written as a simple set of the experiences I have taken from others on the site and compiled here.
    If you want to go argue your heads off about what antenna is going to let you bounce off the ionosphere better, feel free to start another thread about it.
    #50
    NickofTime likes this.
  11. Jun 5, 2013 at 5:00 PM
    #51
    Deathproofduck
    Too many to list
    Exactly. I subbed this for a reason. I don't care for all the tit for tat bs about a better plane for the CB. If they truly loved CB's they would buy my Duck's (shameless plug) because they would recognize it from "CONVOY"!!!!!
  12. Jun 5, 2013 at 5:58 PM
    #52
    stewartx
    Huntsville AL
    Once again, "there's misleading info and several inaccuracies in sections 3 & 7." If you don't care about that, fine. My advice was (and is) intended for those who do. Have a nice day.
  13. Jun 6, 2013 at 5:45 AM
    #53
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Nothing is misleading, I just didn't go into detail about placement because everyone has a different truck setup. And mounting on the roof is not practical for everyone.
    Try contributing to the information instead of just a blank statement of "it's wrong".
  14. Jun 6, 2013 at 6:04 AM
    #54
    TacoFMS
    Justin
    Louisa County, VA
    Well OP all i have to say about this entire thread (minus a couple of post that IMO should never have been posted) is that it is fantastic for someone wanting to know the basics to get up and running. Sure, like others have stated, if you want to go all obsessive over cb stuff then this may not be the thread for you, but heck if you are like most of us that have posted in here and just want some basics to understand what we need to do and how to do it to make our cb's preform properly its perfect! so I say good job and thank you!
  15. Jun 6, 2013 at 1:10 PM
    #55
    stewartx
    Huntsville AL
    Oh, you've made it very clear throughout that you don't want conflicting viewpoints. So, to avoid an argument (as had happened in other similar threads), I recommended more independent, more authoritarian, sources of information instead. If anyone likes, they can argue with those instead. :D
    Anyway, I've said enough - except to again say your information is very good overall. I'm not here to nitpick and there's very little to nitpick about. However, antenna placement on a vehicle is important. The ground plane that provides is effectively one-half of the antenna. The antenna will work without, but substantially better with.
  16. Jun 6, 2013 at 1:19 PM
    #56
    Manwithoutaplan
    ID
    But good thing this information has been regurgitated over and over again in this forum.
  17. Jun 6, 2013 at 1:28 PM
    #57
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
  18. Jun 6, 2013 at 2:20 PM
    #58
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
  19. Jun 7, 2013 at 5:47 AM
    #59
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Nice write up. +1 for taking the time to do it.
  20. Jun 8, 2013 at 7:37 AM
    #60
    Thorny
    Thorny Well-Known Member
    Dean
    Northern CA
    2010 4X4 DCLB SR5
    Good write up - thanks for the information.
