CB radio not transmitting
Discussion in 'Audio & Video' started by Slysky13, Mar 29, 2018.
  1. Mar 29, 2018 at 3:42 PM
    Slysky13
    Slysky13 [OP] Member
    05 access cab tacom 5 lug
    set up my CB radio with a 4 foot fire stik antenna kit recently. flowed the instructions on the kit and but I’m not receiving or transmuting any signal. Can anyone give me any advice or trouble shooting the problem.
  2. Mar 29, 2018 at 4:41 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Step 1. Verify the antenna cable isn't broken. Using an ohm meter, make sure there is continuity on the center core and on the outer shield.
    Step 2. Verify the antenna cable isn't shorted. Using an ohm meter, make sure there isn't any continuity between the center core and outer shield.
    Step 3. Make sure the cable ends are securely attached to the radio and antenna.
    Step 4. If the antenna requires a ground plane, make sure the mount has a good ground.
    Step 5. Tune the antenna with a SWR meter.
    Don't key the radio (transmit) until you know the antenna connection is good. You can damage the radio if you attempt to transmit without an antenna.
  3. Mar 29, 2018 at 7:36 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Make sure the switch for the pa/cb isn't in the pa position. Don't ask me why.
  4. Mar 29, 2018 at 11:56 PM
    Slysky13
    I made sure the CB/PA switch was on the right setting. I also tried to tune the antenna with my SWR meter, but nothing. I’m not getting an SWR reading. The antenna and coax cable should be good they are both brand new. Could my radio be shot?
  5. Mar 30, 2018 at 4:48 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Check the cable to make sure it's not broken or shorted. Even though it's new, it can be bad.
