CB radio questions that need answering
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03TacomaLimited, Dec 5, 2014.
  1. Dec 5, 2014 at 7:42 PM
    03TacomaLimited
    03TacomaLimited [OP] Active Member
    Conner
    Tuscaloosa
    2017 DCSB SR5
    None as of yet
    Ok so I'm about to rig up a cb in my 03 taco 4 door. My questions are what antennas are recommended, what's the best rout for my coax, and if need be how can i ground the antenna from its mount in the center of my toolbox
  2. Dec 5, 2014 at 7:46 PM
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Firestik
    Firestik
    Firestik
    That's all you pretty much need to know :)
    Just kidding. I have a 4foot firestik on my truck, and I have it grounded into the tail light ground (it's a long story). The mount I have has a spot on it specifically to wire a ground onto. It's a BAMF mount. The radio itself isn't as important as what antenna you buy. So don't scrimp on the antenna, but if budgets don't allow for a high end radio a nice Cobra 19 will do.
  3. Dec 5, 2014 at 7:51 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Don't listen to Sam lol. Are you in woods a lot? Parking garages or park in a garage? Do you want the farthest range possible?
  4. Dec 5, 2014 at 7:53 PM
    1993t100
    Big Sexy
    Nebraska
    :facepalm:
    Don't get a whip lol. Fiberglass antennas 4 dayz
  5. Dec 5, 2014 at 7:54 PM
    smmarine
    Melbourne FL
    Go away Sam. Whips are for real men :p
  6. Dec 5, 2014 at 7:57 PM
    1993t100
    Big Sexy
    Nebraska
    Oh, so it's that kinda party...with whips and shit ;)
  7. Dec 5, 2014 at 8:01 PM
    03TacomaLimited
    Conner
    Tuscaloosa
    2017 DCSB SR5
    None as of yet
    Well right now i have a wilson 5 1/2 ft antenna but am planning on getting a whip later. Typically my truck stays in the woods. My main concern is a poor antenna ground where i want to put it on my toolbox.
  8. Dec 5, 2014 at 8:05 PM
    1993t100
    Big Sexy
    Nebraska
    Ground it directly to the frame? :notsure:
  9. Dec 5, 2014 at 8:06 PM
    smmarine
    Melbourne FL
    Mine is in the middle of my toolbox. My toolbox is bolted to my bed, and the mount is bolted to my toolbox. My ground is fine, only issue I have is the bed is steel, the toolbox is aluminum, and the whip mount is stainless. So I get galvanic corrosion buildup due to the dissimilar metals and have to clean all the bolts once a year cause I loose ground when it builds up and my SWRs go high
  10. Dec 5, 2014 at 8:07 PM
    smmarine
    Melbourne FL
    RF grounding is different. You can't just run a wire to the frame. It helps, but no enough
  11. Dec 5, 2014 at 8:09 PM
    03TacomaLimited
    Conner
    Tuscaloosa
    2017 DCSB SR5
    None as of yet
    If i do ground it to the frame can i just use some wire or should i use an actual grounding strap?
  12. Dec 5, 2014 at 8:12 PM
    1993t100
    Big Sexy
    Nebraska
    Wire
  13. Dec 5, 2014 at 8:42 PM
    smmarine
    Melbourne FL
    It's not going to work. Grounding strap would work the best, but a full ground is what is needed. I had a wire to my frame and it does nothing. RF ground doesn't work like DC electricity ground.
  14. Dec 5, 2014 at 8:53 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I recommend a 4' Wilson antenna. They outperform firesticks of the same length and are flexible.
    Grounding with regular wire is fine when additional grounding is needed. However, if your ground wire is too long, it will negate your best intensions. Keep it short. When I installed my unit, I tested with a ohm meter. Got such a low reading, I decided not to install any additional ground straps. I have both a cb and ham antennas on my light bar behind my cab. Both work really well.
  15. Dec 5, 2014 at 9:07 PM
    03TacomaLimited
    Conner
    Tuscaloosa
    2017 DCSB SR5
    None as of yet
    So basically i should get a good ground from my tool box being metal on metal with the bed? Another question, how was tuning your whip?
  16. Dec 5, 2014 at 9:09 PM
    smmarine
    Melbourne FL
    Mine had plenty low SWR so I never did a thing to my whip
  17. Dec 5, 2014 at 10:18 PM
    AustinDeh
    AustinDeh Well-Known Member
    Austin
    SoCal
    04 SR5 TRD 4x4
    Definitely the 4' Wilson Flex
    I didnt need a ground for my setup and its mounted right behind my cab. Didn't have any issue with it slapping the cab either.
  18. Dec 6, 2014 at 1:18 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I have had 2 Wilson 2000 truckers. Will never get anything else.
  19. Dec 6, 2014 at 3:44 AM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
  20. Dec 6, 2014 at 10:47 AM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    I have a cheap knock off of a 4' red firestik mounted it to the ladder rack on my cap using a spring mount. I bought 15 or 20'of coax on ebay for i think $10-
    It works really good, i talk to a guy that lives 20 miles away on his home base unit while im in my driveway pretty often. He says it sounds good on his end.
    Biggest thing is to get your antenna up as high as possible and set everthing up right.
