CB Radio
Discussion in 'Audio & Video' started by LifeIsGood169, Oct 3, 2011.
  1. Oct 3, 2011 at 5:46 PM
    LifeIsGood169
    LifeIsGood169 [OP] Well-Known Member
    Greg
    Philadelphia
    03 Tacoma XtraCab 2.7L 5spd
    Chime Mod Kenwood Headunit Greased all Zerks, locks, and bushings Reverse Flood Lights Extang Cover Weather stripped tailgate Burner Fog Lights Toggle Switches in Dash
    I'm looking to install a CB radio (probably a more powerful 30w "export" radio - but same principles).
    Any recommendations? Radio, Antenna, Mounting locations, advice? I have a first gen if it matters. Thanks!
    P.S. - Hope this isn't the wrong category - couldn't find a wiring section.
  2. Oct 3, 2011 at 5:56 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Dual whips just to look awesome :D
  3. Oct 3, 2011 at 6:00 PM
    MountainMike
    MountainMike Well-Known Member
    Kentucky
    '99 Tacoma
    Do you have any close up pics of the door jam mount? I am about to mount my radio and am exploring my options as well. Thanks in advance!
  4. Oct 3, 2011 at 7:52 PM
    LifeIsGood169
    Greg
    Philadelphia
    Wow awesome replies. Thanks. Do you ever feel like someone will try to steal your antenna or what did you guys do to prevent theft?
    & about how much range are you getting out of those? Compared to the base model / wattage?
  5. Oct 3, 2011 at 8:17 PM
    LifeIsGood169
    Greg
    Philadelphia
    Is there an easy way to ramp up the 4w power of a CB radio? Like buy something classified as an "export radio" or get certified for 10meter? I know 10m has almost no people compared to CB so I don't want to use it.
  6. Oct 3, 2011 at 8:26 PM
    LifeIsGood169
    Greg
    Philadelphia
    I'm not talking extreme transmissions like 150miles +. I've seen skipping on my uncles HAM and the last thing I want is to hit someone in another state or china. But I definitely feel a range of +/- 20miles is reasonable considering I'm not the type of person to hog air space. 4watts isn't a lot with a 6ft antenna. Just asking what you would do to change it.
    Honestly, if I really wanted <4miles I'd bust out my Motorola walkie-talkies
  7. Oct 3, 2011 at 9:01 PM
    LifeIsGood169
    Greg
    Philadelphia
    I just like having the option in case something pops up. 4miles isn't a lot of range around the Adirondack mountains - it'll probably end up being <1mile too. + I'd love to be able to talk and hear people 20miles away while cruising on the highway. I figure I can keep the output knob down for normal use.
  8. Oct 3, 2011 at 9:12 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    you could always get into sideband CB...
    i had a CB that had upper and lower sideband and i was hitting other operators that were a good 20 to 30 miles away and i live up in a canyon...
    although a HAM with 75w output, you can always find a home base operator somewhere... just scan all available freqs...
  9. Oct 4, 2011 at 5:16 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2002 Sliver-ade-o 2008 P71
    Yes
    Just get yourself a bi-linear amp :anonymous:
  10. Oct 4, 2011 at 4:49 PM
    LifeIsGood169
    Greg
    Philadelphia
    Thanks. You're right; CB has changed a lot in the last 20 years. It's definitely worth having at least a 10mi range.
    I could care less about the law too. But morally I would have a big problem if a modified CB was wrecking other peoples receptions or being used to spam channels... etc. I'll definitely be testing it.
    Edit:
    You linked a 400w amplifier. I'm not even sure if my truck even outputs much over 60-70amps. Do you have a recomendation on something a little more reasonable?
  11. Oct 5, 2011 at 6:35 AM
    LUSETACO
    Dennis
    South Central Pee A
    Yes
  12. Oct 6, 2011 at 8:21 AM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    Nice. I was wondering where do you run your coaxial into the cab of the truck? I have a double whip I am putting together and I am stumped as to how to get the cord throught the cab without having to drill a 1/2 in hole?
    Thanks.
