Cb radio
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dox, Mar 24, 2017.
  1. Mar 24, 2017 at 5:01 PM
    Dox
    Dox [OP] Active Member
    Tim
    2015 tacoma trd black
    None
  2. Mar 24, 2017 at 6:02 PM
    Zredwards
    Zredwards Well-Known Member
    Zach
    Ludowici GA
    2011 Toyota Tacoma Trd
    3 inch lift. 285/70
    For almost half the price just get a cobra 19 it's what I use for dog hunting in my Tacoma with a Wilson 40 on top.
    MarX likes this.
  3. Mar 24, 2017 at 6:20 PM
    Dox
    Tim
    None
    I have a compact midland looking for something super compact.
    EDDO likes this.
  4. Mar 24, 2017 at 6:26 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    I have the Anytone. Don't use it much anymore as people around here have gone VHF. That little radio works great as a CB, but you have to mod it.
  5. Mar 24, 2017 at 9:06 PM
    Dox
    Tim
    None
    What kind of mod?
  6. Mar 24, 2017 at 9:19 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    You have to open it up and de-solder circuit OP2 on the main circuit board. Then when you use it, set it to band DE to run the German frequencies which are the same as ours.
  7. Mar 24, 2017 at 9:24 PM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
  8. Mar 24, 2017 at 10:06 PM
    Dox
    Tim
    None
    Seems easy enough in the pic it looks like op1 is the one solder is that corect?
  9. Mar 25, 2017 at 4:30 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
  10. Mar 25, 2017 at 5:04 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Dox I have a ham radio license N1GYM. that radio is not really cb it is 10 meters you need a license for it. Just get a nice cobra radio and enjoy yourself. You may want to look into a amateur radio license its easy to get, just look for clubs in your area they give the test.........
  11. Mar 25, 2017 at 5:48 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
  12. Mar 25, 2017 at 5:54 AM
    Dox
    Tim
    None
    Thanks buyobuyo ill give that cobra a try.
  13. Mar 25, 2017 at 6:04 AM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    No problem. If I ever finally decide to put in a cb setup, it's what I'll run. There's a board member local to me that runs one that likes it.
  14. Mar 25, 2017 at 7:45 AM
    summiteer
    summiteer Active Member
    Jeremy
    Cedaredge, CO
    2013 Tacoma Dbl Cab Mag Grey
    None.... yet
    I've ran the 75 for years now, love it!
  15. Mar 25, 2017 at 11:37 AM
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    I have this one two but this is to much. dont buy it from this site. You can get it for 90 from Amazon. and i use a 4 foot firestick antenna
  16. Apr 30, 2017 at 5:26 AM
    stratotanker
    stratotanker Member
    Dave
    2004 Tacoma double cab 4X4
    Dox,
    I run the Anytone Smart CB in my Tacoma. As you can see in the pics below, I have mine very nicely mounted inside of the dash where the useless pocket is for the Scoshe aftermarket stereo. Yes there is a mod that has to be performed to make it work on CB but it's a very simple mod that anyone should be able to do. Once you open the radio case bottom using a T-8 torx bit, there's two solder pads inside labeled OP1 and OP2. You simply desolder OP2. You can do this with a 30 watt soldering iron and a solder sucker. Once done, you hook up the radio, turn it on and you will be on all of the legal 40 channels. The nice thing about this radio is it is hands down the smallest CB in the world and it not only fits in the Tacoma, but also (in my case anyways) the Amber lighting matches the Tacoma factory Amber gauge lighting as well. Just make sure you run a good antenna with your radio for best performance. I recommend the Sirio line of antennas as they are head and shoulders above anything else on the market, except for maybe a 102 inch whip.
  17. Apr 30, 2017 at 6:24 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    With this mod, is the output at 4 watts? The tech specs have output at 8.
  18. Apr 30, 2017 at 6:30 AM
    stratotanker
    stratotanker Member
    Dave
    Mine came out to be at 4 watts. I ended up dropping mine to two watts as I run an amp with mine.
  19. Apr 30, 2017 at 6:39 AM
    will.carroll7
    will.carroll7 Well-Known Member
    2023 DCSB TRD OR 4x4 LR
    Whenever you see a CB being sold as outputting more than 4 Watts they're talking about the speaker output. Trying to trick you.
  20. Apr 30, 2017 at 6:39 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
