CB recieving great, transmitting bad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Skyent, Jun 1, 2019.
  1. Jun 2, 2019 at 2:00 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    A few things to add, you want SWR's on ch1 and ch40 as close as possible. Ch19 should be lower.
    As stated, adjust your antenna up and down, 1/4" at a time, then 1/8" to fine tune, and watch as the SWR's move. Takes a little time, but when you get it set, you're done.
    Often a bad ground is the problem. Don't sit near another radio to test, get 100yds away. For tuning the antenna, best to get out in the open, away from tall buildings and trees.
    max_o and AthensTac like this.
  2. Jun 3, 2019 at 5:51 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Did you post a picture of your antenna mount? If so, it's not showing up for me.
    I suggest double check washers and cable connection at the antenna. Firestick should have a plastic washer that prevents the outer threads from touching metal on the mount. Make sure the threaded metal ends of your antenna cable are not touching other metal.
  3. May 5, 2020 at 10:25 AM
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    You ever figure this one out? I have 2 of these radios. One in a Grand Cherokee, and the other in my Tacoma. I Rx in my truck fine, but Tx is broken at best. Similar setup to yours. Radio in the other vehicle Tx is loud and clear. I have swapped antennas and cables, tuned the antennas, and still broken. Pissing me off.
  4. May 5, 2020 at 11:16 AM
    Dravnx
    Dravnx Well-Known Member
    jeff
    Santa Rosa, Ca
    2018 SR5
    When checking the VSWR in the FWD mode, talk loudly into the mike. You should see the power output increase slightly, the needle should flicker, the louder you talk, the more it will flicker. this will indicate that the RF is being modulated. CB's are amplitude modulated. If the VSWR is within tolerance and you don't see a flicker, then either the radio or the mic is bad.
  5. Feb 27, 2023 at 7:41 AM
    west4x4
    west4x4 Un-known Member
    San Bernardino County, CA.
    2019 Tacoma TRD Off-road
    I’m having same issues, but no one can’t here me. I even bought a new mic to see if it’s the mic giving me issues. I ordered a new antenna set up. Hoping that will fix my issue. I’m running A Walmart made in China antenna at the moment.
  6. Feb 27, 2023 at 10:18 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Is it the same radio?
    I also bought one of those but it’s still in the box.
    It sucks when people don’t update if they resolved a problem.
    west4x4 likes this.
  7. Feb 27, 2023 at 10:32 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    1-1.5 is ideal so your standing wave ratio isn't the issue provided you tested it properly with a calibrated meter. Anything between your handset and the radio could be causing a problem. The most likely culprit is your mic since it is the thing that gets the most use (or abuse). Check your connections and that the mic connector is threaded all the way on and all of the contacts are nice and golden colored. Hit the contacts up with an eraser (like an old school #2 pencil eraser) to remove the crud and get the contacts nice and shiny gold/brass looking again. I would also check your radio's ground although this doesn't sound TX/RX related. It is more likely the handset's ground is crappy.
    Did you check how much power is getting out at the back of the radio with a watt meter? Also: including the model CB would help troubleshoot the issue. Another thing: are you sure you want to be running CB in California? Those bands are so crowded most in the off road community are running VHF. You may want to consider a 15W GMRS radio and a GMRS license through the FCC - it is quick and costs like $40 (or thereabouts) and is good for 10 years and applies to everyone in your family.
    Edit: your antenna is grounded to wherever you have it mounted right? Like bare metal to bare metal? If you have it on your roof you need to grind the paint off so the antenna's grounding surface is touching the bare metal of your vehicle. That or run a separate ground cable from the antenna to the frame or something.
